Poodles;1698036 said:You have another thread about getting the MAFT Pro tuned, that could be your entire issue...
Outside of that, coolant leak.
gottadiesel;1698166 said:Hey poodles, as you saw, I have been assisting Shawn with the MaftPro - not being a great mind reader :icon_bigg I am missing your thoughts on what you think the entire issue could be... I will be the first to admit that I am not an expert, did you see something in that thread that I missed that concerns you?
I respect your opinion (most of the time :naughtyso would love to hear any insight that you may have also...
jdmfreak;1698235 said:OK here is the conclusion.......so far.........
just because you maxed out stock temp gauge
and your car looked like this ::bhg::
doesnt always mean BHG
MHG FTW!!!!!
so we hooked it up to a pressure gauge and at 170 deg it was at 13 psi
at 185 it was at 15 psi at 195 deg it was at 17 psi
my stock radiator cap is 13psi... i was blowing water out the overflow before my thermostat opened
turned on electric fans pressure dropped to 10 psi and temp came to rest around 150 deg at idle
i got a 20 psi cap didnt overheat all the way home driving pretty hard and letting it idle a couple times
fingers crossed it wont overheat again![]()
Poodles;1698284 said:Namely timing (even without timing control used, piggybacks mess with timing curves anything they're tuned)
Honestly, you have other issues if you're getting that much pressure. The higher pressure cap is a band aid at this point...
jdmfreak;1698297 said:so are suggesting that timing may be causing higher pressures?? should i hook up the timing monitor so i can keep an eye on it???
---------- Post added at 03:42 PM ---------- Previous post was at 03:35 PM ----------
even before we hooked it up to the pressure tester a guy at the shop said he thought that the cap pressure was too low and it was the problem because with big turbos he commonly sees pressure at 190 deg at 14-20 psi........was he speaking generally and our cars always run lower pressures???
so is the apexi 1.3 from driftmotion a bad thing to put on since it hides other issues???
just wondering because i was gonna order one
jetjock;1699309 said:You're welcome.
Sent from my keyboard using fat fingers
