Well other than the 10mm allen socket with a breaker bar, nothing lol. I thought you meant the stripped bolt my mistake.
No probs was just checking as the Craftsman kit you posted was for normal bolts and I wasn't sure if you still had the original bolts or maybe someone had swapped in some ARP Bolts (hex head)Doat;1852556 said:Well other than the 10mm allen socket with a breaker bar, nothing lol. I thought you meant the stripped bolt my mistake.
Never tested that Cyrus, I don't have any 7M parts here or I'd check.Cyrus;1852806 said:IJ, is it possible to have the valves hit each other if you are spinning one cam and not the other? if so, be careful not to do that, Doat.![]()
No 12mm is far too big, just order one from that Sears?Doat;1852827 said:Well I went to two local stores that have lots of hex bits and they only have 12mm or they don't have 7/16" and in order to use the 12mm I'd need to remove the cam, which I don't mind doing as long as it will work. Could I use the 12mm or is that too big?
