do the stuff with the belt first (get crank to TDC on #1, align cam gears with timing marks on #2 timing cover, run your belt counter clockwise starting at the crank pulley, get your belt tension right and your tensioner torqued down to the correct value).
then put your jumper in between E1 and TE1 and start the car. run it til it reaches normal operating temperatures.
then use your timing light and, with the car still running, rotate the CPS until the TDC mark on your damper lines up with the 10 degree line on the block.
then tighten down your CPS and check the timing again to be sure you havent wiggled it while tightening the stay bolt.
then you are done! go do some burnouts.
