should be, just make sure you dont have any clogs. the smallest (and most likely to clog) pinch point is probably the throttle body orifice. make sure that is nice and clean.
Doat;1859997 said:Stock, our cars come with platinum NGKs ...
Incorrect. The oil pump drive shaft is driven by the timing belt. This probably doesn't make a difference for removing the crank pulley, since GENERALLY the crank pulley being on means that the timing belt is also on.Cyrus;1860005 said:but oil is all crank driven.
