Well had another go around with a fluid spewing from the engine... This time it was oil, I was on my way to work. I jumped on the highway and noticed a smoke cloud starting to form behind me, then I started to smell it. For sure I was leaking a lot of oil, without any spare oil in the car I hit the exit ramp and spun around back home. When I pulled in the driveway oil pressure was still good, but i knew a lot had gone. I shut it down and looked under it, oil everywhere. As a precaution I grabbed the fire extinguisher but it wasn’t needed.
After I got home from work addressed the situation, it appears the o-ring on the oil pressure sending unit couldn’t hold the oil back any longer, the o-ring did not appear damaged but I knew it was the cause. I used a new o-ring for the AC lines, torqued it down, fill it up with oil, then started it and had no more leaks. When I was under the car I noticed the lower radiator hose was leaking coolant, and the clutch slave cylinder is leaking fluid........ Jeeze, what a day. So now I have to pull the trans to tighten up the lines.
I started pulling it apart, but first I cleaned as much oil off as I could. Did I mention it was everywhere.......... Purple power, water, and a bunch of those blue shop towels cleaned up everything nicely. I managed to get the exhaust out and got the driveshaft ready. Now I just need to drain the transmission fluid into a clean oil pan and pull it.
