I dont like re-using coolant from the drain as it tends to dribble down different things and pick up dirt on the way, maybe im doing something wrong but i prefer to just fill fresh stuff back in. Also, someone mentioned i rebuilt my fan clutch, no, i never did that im not sure where you read that.
About the damper slipping, how could this happen, i just did the timing belt recently and put the damper back on and the key and everything was in perfect shape, i will check this still though.
About the fan clutch again, is OEM the only way to go or to ones from parts stores work equally and last equally?
