Dirgle;1287244 said:Are you sure it didn't move? The first time I did this test I thought it wasn't moving. Then I realized that it moves ever so slightly, barely noticeable. The ISCV doesn't affect idle quality only idle speed. no matter where the ISCV sets itself the air it bypasses is still metered and appropriate fuel is added.
Was there anything you changed or anything you modified at or around the time your idle became an issue. Anything at all even if it's not related.
it kida fluttered, but when i put the valve together and tested it, it looked to me to be open.
i have done many things in the past few months since it started, but has gotten worse.
i am going to check the bic downpipe and make sure it is sealed tight. thanks for letting me know about the iscv, dam i thought i was on to something.
edit: ok just checked it agian and it is working. it takes many repeat taps back and forth over and over. then it will max out and start going down. i am working on this all day. untill it is down anyways.
