sory it took so long to get back to this, but i have been working on it alittle at a time. my wife is geating ready to have a baby and time is not mine. so i work on my baby at night:cry:
what has been done on check list:
put new gaskets on TB, ISC, valve covers.
installed safc2 and took out safc1, (forgot to hook up blue wire to vf, dam!)
installed treadstone IC and synapse bov. (no boost leaks found)
checked all sparkplug gaps. (all were @ .28)
recalibrated tps, (but safc2 is reading on WOT @ 3.45V) should it be @ 3v?
put new ground on coilpack
set timing to 8* ( so i will be safe to tune the safc)
have not attempted to fix the leaking seal on the CPS, but its next!
when i stared the car today it ran good, and then as it warmed up and the A/f"s where rising from 14.5 it started to idle worse and worse untill i thaught the car was going to die. i turned it off and went for an inspection under the hood, but found nothing out of order. The A/F"s reached about 16.8 and would blink into the 17.0"s then i would shut it down.
i unplugged the oem o2 sensor and it seem to run fine when the A/F"s were @ 13.8 to 14.3. but then the A/F"s whould rise again. a can do some video footage of the cold start to warm up, or what ever you think will help you get a better idea of what i need to try next.
i live in so cal, Temecula ca. if there is anyone out there that can help me work on my car let me know. i will drive anywere from SD, to LA. let me know!
