Thanks for the confidence Mike! Heading down that way...That would be one SERIOUS road trip! Hopefully, I'll be able to take you up on that offer!
Well...these OBX Cam Gears are less than par. The machine work is a joke! The set screws won't set, the adjustment part of the gear won't adjust because the set screws are binding, and even if those problems weren't present, they still wouldn't work because they sit too far back and hit the rear timing plate screws. (was that a run-on senence...)
I'll definitely be posting a review on these gears...
At any rate, here is a pic of my first of many modifying stages in order to get these gears to work. This is trimming the screw heads down so there's adequate clearance in the adjustment grooves.
