The heater hose comes out there and goes into the heater switch. There is a large fiting that goes into the head that the hose is connected to. It maybe leaking from either one, most likely the hose. It maybe small enough that it's just blowing down over the bellhousing not really dripping, and then drying after driving. CRE has some good sugestions.ImperfectSupra said:a mechanic have told me after a compression (very good compression) and leak test that the leak is some where between the head and firewall but i cant see any coolant or wet spots. he said that i could be a hose or plate. or crack block. ? any suggestion. its supposedly BEhind the coolant hose that come out of the head by the firewall. i HavE replaced the thermostat and cap with geuine toyota parts a few weeks ago. By the way the car doesnt overheat just lose a little coolant......Meanwhile im doing a complete flush with a liter of radiator cleaner. just have to drive for 3 more hours. thankd
Check the small rubber cap just under the header also, as it has a tendacy to dry out due to heat and slowly get worse until it completely lets loose. I fixed mine with a piece of heater hose and a large bolt. I was tired of replacing it with the cheap caps you find at the auto stores.
