Brandon's Build
BrandonW
1,300
N.J.
its weird how the gasket set says
part name: head gasket set
models: toyota crown yr22
engine: 4y-ec 2237cc 4cyl (has the straight 6 hg in there lol)
years: 1985~
anything to worry about?
looks to be the right set so i shouldn't have any problem i just thought that was weird, i got it from a2 so i should have no problems (and yes i will be getting a mhg)
BrandonW
1,300
N.J.
i don't know if it will fit good though lol i did 9.5 all around with the stock height there is no rubbing but lowered there may be a little not sure but money has to be spent else where at this time, car is feeling a little weak im at 210,000+ miles
BrandonW
1,300
N.J.
uh oh the 7.5 fuse is back
well the one that controls the windows ac and dash was working for about at least 2 weeks if not more
and today when i was leaving for work i didn't have those things and the fuse was blown, again before leaving work so i put another one in
and does anyone know where (if this is a good enough description) a red wire goes in there that plugs into the fuse box or whatever its called there is a green wire and i think the red one plugs in right under it
BrandonW
1,300
N.J.
few new things to add to my thread here
new toyota water pump
new toyota ps pump
new toyota timing belt tensioner and the spring
cooleeze pipes from a member on the boards here
BrandonW
1,300
N.J.
Nomad707;1188270 said:
nice build.. this car is definately in great hands!
P.S. tell your friend and his uncle to torque the head to like 65-70 LBS if using stock bolts.
nah im going to get arp
BrandonW
1,300
N.J.
forgot to put this in post with the other new things i had, i knew i was missing something
new toyota oil pump
new toyota accordion hose
new toyota horseshoe gasket and 2 other gaskets i think they are for the timing belt case area or something
and if arizzle hasn't seen any other posts with my exhaust and stuff he wanted to see what my rims looked like on my car
BrandonW
1,300
N.J.
thanks, im really happy at how they look and how flush they are
i really don't think im going to lower it at all though
and i saw that driftmotion sale so i purchased 4 new things that should be here in a week or so i'll post up some pictures when that stuff gets here
BrandonW
1,300
N.J.
little update
toyota clutch disc
toyota pressure plate
toyota throw out bearing and pilot bearing
arp flywheel bolts
arp head studs
arp main studs
BrandonW
1,300
N.J.
got something delivered today
Supra28
Supramanian
Aug 17, 2006
1,921
Columbus, OH/Kansas
The car looks really good, especially with those rims.
I'm curious as to why you've decided not to lower the car. Is it because of scraping issues? :biglaugh:
BrandonW
1,300
N.J.
well i dd my car and i know some dd their supra and lower it
but i don't want to worry about scraping i do get a little bit of rubbing on hard dips because of my rims, my exhaust and i really like the way my car looks without being lowered so i just never really planned on it
oh and the radiator i got is a 3 row
BrandonW
1,300
N.J.
when buying a replacement heater core would it be best to buy a toyota unit (of course way more expensive) or would i be ok just getting a autozone unit?
any differences?
and is there anything else i should replace with it that has to do with the heater core? of course i would only want it to be a one time job
