Brandon's Build
BrandonW
1,300
N.J.
Thanks! And hey there is also a wheel fitment and question thread in the general MKIII section that will give you some more answers if you haven't checked that out before
Grandavi
2,664
Calgary, Alberta, Canada
BrandonW;2094249 said:
currently running just a 255/40/17 with about a finger of space I do not rub with these and my fenders are not rolled you might be able to pull that off with rolled fenders
I think 255's with that perfect fit is pretty good. I have 265's on mine with a +42 offset that probably has the same space on the inside, but would rub if I was dropped as low as you are. 275's can fit, but you will need a bit of gap or rolled as Brandon said.
