The interior of my car needs a lot of help. The carpets in front were so worn out and impregnated with so much nasty old dirt, I just threw them out. I found replacement carpets here:
http://www.stockinteriors.com/CutSewnCarpet.asp?Itemid=6628&MakeId=28&ModelId=499
I haven't ordered yet. Not too important until the car actually runs!
Also the center console needs refreshing. It's in pretty good shape except all the chrome over plastic has peeled away, leaving all that ugly yellowish plastic. I can't afford to send the part away, so I decided to try painting it myself. You should be feeling some foreboding after reading that last sentance....
I cleaned with Simple green and water, and gently hosed it all off and let dry.
Using JB Weld to strengthen the cracks in the plastic. Everything is old and brittle
Masking off, very carefully! Trying to do a good job. The dull grey-silver you see in the middle is paint over plastic. It matches the plastic on the gauge cluster, so I want to preserve it.
All masked off
Under coat of gloss black. I was reading on hobby websites about how to get a good chrome spray, and they all had good results by spraying gloss black first.
And after a few coats of chrome....
Oh no! Over spray! I thought I had masked off really well.
If I can clean up the over spray with a bit of paint thinner, then this will look better. If not, then I have to re-do it.
Also, I had a really hard time with the chrome spray. I didn't get a smooth coat. Overall, not a success.
The opening in the console is for a clock on some better-optioned car. Mine came with no tachometer and a clock where one would go. I wonder what the tachometer and console clock upgrade cost in 1973? $20? Cheapskates! I think I will install a clock in that space myself.
