Hey all, been a few weeks since my last update. Just been enjoying the car and doing a couple small things like getting the wideband bung installed in the down pipe and running that set of wires through the firewall. Couple other little things here and there but mainly cruising around town and having fun driving the car.
My next plan of attack for things to do is getting the wiring done for the wideband and the vacuum lines run for the boost part of the gauge.
I've also ordered a new ROM chip for my HKS F-CON piggy back system for 550 injectors and once I've the to hang of playing with the new wideband/boost/failsafe gauge then I'll install the F-CON/FCD system and play with a little bit of tuning. Nothing too major but I'd like to see if I can turn the boost up to around 10-12 psi. Shouldn't be a problem as most stock set ups see that amount of boost with no worries. 15-18 psi will be my goal for the current set up that is not all installed yet and that will be where I stay until I decide to do more to the car.
I wish there were some better instructions on the set up and install of the F-CON system but I guess it seems pretty straight forward and found a few gems of wisdom here from Crisp who seems to be an HKS proponent. Trial and error is not something I want to deal with when it could detonate my engine so I'll be watching my AFR's like a hawk while messing around with the fuel system and engine management systems.
Snapped a couple more pics of the F-CON harness and the FCD that's already wired up to the harness from the PO. Going to double check the wiring but it seems like everything is where it's supposed to be.
^ FCD wiring to the harness.
^ The wires that are running through the firewall from here are for the pressure sensor in the engine compartment which is also already all wired and had the vacuum lines tapped. Should be plug and play once I get the new ROM chip installed into the E type F-CON.
Thanks for reading and happy modding guys!
-Taylor
