MA70witBoost;1316282 said:what you talking bout willis?
He's just saying that they flow a ton of air, enough that if you were to put em on the ground and activate them that they would literally hover.
Right Ian?
MA70witBoost;1316288 said:sweet... im just concerned about fitment. I dont exactly have my supra infront of me right now but im pretty sure it'd be difficult to get a full sized E fan infront of the condenser between the drier and everything else thats there.
old skool;1316329 said:
MA70witBoost;1316360 said:what? make it fit? use a shoe horn? Im sure its do-able but im sure your doing what i did and throwing one behind the Radiator between it and the motor. Thats easy. Done that already. Im sure the front side is alot harder than the back.
IJ.;1316267 said:Never seen one sorry.
IJ.;1316231 said:How about rush hour with the AC on?
mr.b;1316465 said:What about the Flexalite? Are those good efans?
877m;1324204 said:no those suck when you rev them up the flex and flatin out and dontmove much air and if you were to ever hit your hand on it that would mess you up
steveaw11;1324505 said:He is talking about the electrics... efans.
FAL is flexalite also, just there import marketed brand.
I think the Supra FAL fan is just a colored Flexalite 210 also, the 210 is a bit cheaper too.
IJ.;1315376 said:Local car here a Ford AU Falcon, I believe Ford Contour are simular.
tekdeus;1330006 said:The Flex-a-lite fan conotroller boxes are garbage. Twice on my car, the fans pulled enough current to melt the solder on the circuit board and have the terminal pull right off. I ended up modding the box with a separate relay.
upgradedsupra;1330018 said:I currently run a custom dual pass rad with electric fans and they cool fine. They are controlled by the MoTeC and in super hot out side temps, the car stays nice and cool too.
On a previous set-up, I ran same as brad and had no issues either.
Duane
gaboonviper85;1330493 said:super hot outside temps...says the Canadian LOL....just cause the snow doesn't stick in the summer doesn't mean it's "super hot"...LOL jk
