benefits to electric fans?
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
MA70witBoost;1316282 said:
what you talking bout willis?
He's just saying that they flow a ton of air, enough that if you were to put em on the ground and activate them that they would literally hover.
Right Ian?
old skool
92
Milwaukee
MA70witBoost;1316288 said:
sweet... im just concerned about fitment. I dont exactly have my supra infront of me right now but im pretty sure it'd be difficult to get a full sized E fan infront of the condenser between the drier and everything else thats there.
old skool
92
Milwaukee
MA70witBoost;1316360 said:
what? make it fit? use a shoe horn? Im sure its do-able but im sure your doing what i did and throwing one behind the Radiator between it and the motor. Thats easy. Done that already. Im sure the front side is alot harder than the back.
yeah man, i was just gonna do a fan delete and throw an electric one in the stock location behind the rad. i didnt even consider throwing multiple fans in diff locations...that and i'm just retarded today. it took me a couple reads to figure out what you were talking about in that previous post.
8,898
IJ.;1316267 said:
Never seen one sorry.
Pick up a 3640 lb MA70 and you can see them. Mine has one in front, one in back, and the stock clutch assembly.
For the O.P,if you want maximum cooling, instead of a range that ECU is set to see, hardwire a toggle switch in lieu of temp sensors. Don't forget to turn them on when you switch on the A/C. And install a new factory fan clutch. The only benifit is if you have a sideways engine, or you need to eliminate all parasitic losses, such as a track car.
877m
65
Lewiston, NY
IJ.;1316231 said:
How about rush hour with the AC on?
well i don really live in the city lol and i dont use the ac too much a used it once last year and my alternator was no good so i didnt useit at all and i just put i new one in. but i mean i cant complane about them at all i will take some pics and poast them when i get a chance
877m
65
Lewiston, NY
mr.b;1316465 said:
What about the Flexalite? Are those good efans?
no those suck when you rev them up the flex and flatin out and dontmove much air and if you were to ever hit your hand on it that would mess you up
steveaw11
116
georgia
He is talking about the electrics... efans.
FAL is flexalite also, just there import marketed brand.
I think the Supra FAL fan is just a colored Flexalite 210 also, the 210 is a bit cheaper too.
877m
65
Lewiston, NY
oh.... i thought he was talkin about those metal ones that go where the crank fan is my buddy put one of those on his car and it was horrible. and god would i hate to see any one get there hand cought by one of those
Tire Shredder
569
Oshawa
IJ.;1315376 said:
Local car here a Ford AU Falcon, I believe Ford Contour are simular.
mk2 guys use these fans all the time. ford contour here in the US, V6 ones only. a good, cheaper solution but I think this is an even nicer one:
I have one of these in my mk2. he makes one for the mk3 too. I can't remember phil's username on this forum, but he is here too, I think. Regardless, send him an e-mail. Details here: http://forums.celicasupra.com/showthread.php?t=37610
I don't have any complaints about the fans or his service. CNC laser cut aluminum. This being said, I would spend my money elsewhere before going with electric fans. Mk2's have a unique fitment situation that means electric fans are a good solution for a 7m swapped car. with a cooling system, reliability is paramount and that is not compromised at all with the stock setup...
grimreaper
2,180
Dallas
Any electric fan worth relying on is going to put a beating on an 80amp alternator for DD use. DO NOT cheap out on this. That includes the wiring and relays/fuses.
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
The Flex-a-lite fan conotroller boxes are garbage. Twice on my car, the fans pulled enough current to melt the solder on the circuit board and have the terminal pull right off. I ended up modding the box with a separate relay.
Dec 3, 2003
6,653
Canada
I currently run a custom dual pass rad with electric fans and they cool fine. They are controlled by the MoTeC and in super hot out side temps, the car stays nice and cool too. :)
On a previous set-up, I ran same as brad and had no issues either.
Duane
mr.b
densesmoke
Jan 23, 2009
Homeless in PR
I was fixing to get the Flexalite, but now I'm confused. You still think, it's a good buy, or not?
Thanks
gaboonviper85
3,236
Northeast Philly
Duane
super hot outside temps...says the Canadian LOL....just cause the snow doesn't stick in the summer doesn't mean it's "super hot"...LOL jk
mr.b
densesmoke
Jan 23, 2009
Homeless in PR
Which temp. could it be "super hot" for him?
I know that 95/100 fahrenheit in Puerto Rico is "super hot" for me...lol.
