indy_mk3;1062118 said:
ok thanks man and i was just gonna ask in the pic it looks like you cut the wires coming from the ecu and connected them straight to the maft pro harness leaving the harness side all disconnected...i thought you only do that to the KS green wire and for the rest you cut your supposed to cut the wires from the ecu and then connect the maft pro wires in with the wires coming from the harness side as well. And my car has had a weird life and about 4 different engines that i know of and who know's how many owners and by looking at the ecu im positive it has been swapped but it does say "87 supra M/T"
Do not cut ANY ecu wires besides the KS! There is no need to unless you are getting into more advanced things like timing control.
If the manual says "tap into", then take the insulation off a 2cm section of the ecu harness about 6-10cm back from the connector (I use a small wire stripper to pinch the plastic at each end and an exacto knife to cut along the length), but do NOT cut the wires.
Then take the correct maftpro harness wire, cut a 10-20cm length off, strip one end, and wrap it around the exposed section on the ecu harness wire. Align the wires parallel to eachother as opposed to perpendicular. Solder this piece. Then wrap it in electrical tape.
Strip the other end of the short piece, and crimp one of the connectors you see in place. Connect it to the crimp connector you put on the maftpro harness wire, and you're done.
If the manual says "splice", that is the only time you actually need to cut an ecu wire.
The pic I attached shows tapped wires coming from the ecu harness. The extra wires coming out the top of the tape go to the connectors you can see in the previous picture. If you can get shrinking tape for this, it's even better!
