Hmmm. Interesting this thread would come up again now. Wish I hadn't wasted my time on the ungrateful but at least others can benefit from the info.
So it works fine for an hour? That's not much good is it? I understand you're against it but I'd change the condenser if I were you. First because you'll have a leak tight system. Second because the replacement condenser will likely be better than the original one. Parallel flow for example. It'll result in a better performing system.
Next would be repair of the stock condenser if possible. There are special brazes and solders made just for those jobs. You may have to remove it from the car.
Sealants. Most AC guys dislike them and I'm no exception. They work but not for large leaks. The other problem is once they're in there you're sort of screwed. They can raise hell with refrigerant recovery systems and even the AC system itself by plugging the expansion valve. Rare but it happens. If you try a sealant expect any shop that services the system later on to be unhappy. They might even refuse. That said see a couple of posts back for a sealant that has a reputation for working, at least on evaps and smaller leaks.
Free 134 huh? Lucky you. The stuff sure has gone up in price over the last few years. I still have lots of 12 around I bought cheap. Problem is I keep giving it away (you know who you are
