CPT: I'm typed in several aircraft. I currently operate the Canadair Regional Jet for work and the Aero Vodochody L-39 seen in my avatar for fun. In addition I occasionally fly a Lear 35 and CitationJet for a former employer.
I'm not familiar with the Autozone stuff so I can't comment on it. The use of sealants and additives is a hotly debated subject among AC techs. Some swear by them while others swear at them. My opinion is that sealants are bad and you should never put anything but refrigerant, oil, and tracer dye into an MVAC system. One problem is sealants mess up recovery machines so most AC techs don't like them. They've also been known to clog up the tiny passages in orifice tubes and expansion valves which are at the heart of a MVAC system. Rare but it happens.
Sealants should only be used on leaking evaporators and then only when the car isn't worth fixing right. For example if someone can't afford the labor to replace a bad evap (usually a big job) or if the car is too old to put much money into. In that case a sealant can get the AC going again for cheap. However if you plan on keeping the car I suggest avoiding them.
All other types of leaks should be repaired correctly.
That said, there are a number of sealant products on the market that work. If you use one don't buy it from an auto store. Use a "professional" product. Cryoseal comes to mind:
http://tinyurl.com/p2avo
Anyone with questions about MVAC work should ask for opinions on the two forums I linked to in an earlier post. Sadly, MVAC shops can be among the worst scammers in the automotive repair world so it's a good subject to learn something about. You needn't buy the gear and do the work yourself but at least the shops will be unable to BS you.
Johnathan: Look in your TSRM to locate the dual pressure switch. It's located on the fender near the turbo. One is for high pressure and one for low. Unplug the connector and check both switches for continuity. Both should have it ie; be closed.
