I thought I would really trust this guy, turns out I was wrong.
Warranty info is BOGUS!!! He will not honor warranty for XSPower.
I have tons of proof that the turbo was bad during the 6 months of the warranty period, and I was in contact with him, yet he still refuses to warranty because NOW it is after the warranty by a month.
98mkiv is a RIP-OFF!!!!!
More information can be found here in these two links.
I have less than 5,000 miles on the turbo, but it started failing the moment I put it on.
Oil had been leaking out between the turbine housing and the compressor housing for quite some time. I notified XSPower about the problem but they refused to work with me.
Well now it got the point where I started creating a smoke screen behind me, and pretty much killing everybody around me. VERY embaressing to say the least.
I pulled the turbo off last night and snapped a few pictures. XSPower then uses 6 point torque bit(but with flat points) to hold on the backplate, so I couldn't tear the turbo completely down yet to look at the exact failure.
Something else I noticed. For balancing the compressor wheel. I would have figured it would have been machined. NOT EVEN! Looks like they took a grinding wheel to it. I will have to take a picture of that. I mean seriously, a grinder?
I think I will stick to the real deal now, just like I no longer mess with piggy backs.
As soon as I pulled off the turbine housing, oil just poured out. You can also see all the oil residue and burnt oil on the housing.
There is no problem with the gasket, and it is free and clear of any debris, just to be sure it was not a problem with the return.
Here you can see the ID of the hose I am using. The batter was dead on my calipes, but that is spot on .5"
Here you can see there are NO kinds in the return line, top then bottom.
