While that was going on MrsuspectSupra was busy welding some stuff for me:
Timing crank wheel:
Coolant water neck:
water bypass pipe for single conversion:
usdm GTE pump:
He also extended the harness(still need to provide him with my body plugs to finish)
Got to replace serpentine pulley bearing:
Pretty easy i might say:
Engine block paint prep:
degreased and washed the block about 4 times to remove all the grease:
Dried and scuffed with red scotch brite:
After about 3 coats of hight temp paint: :naughty:
Timing crank wheel:
Coolant water neck:
usdm GTE pump:
