leftynridge;1669531 said:I would clear coat those lenses while your at it. A friend of mine used the same stuff and after a while of sitting in the sun it will be begin to fade and even chip but if you clear coat it turns out perfect.
---------- Post added at 09:05 AM ---------- Previous post was at 08:57 AM ----------
You also can go to www.energysuspensionparts.com They also sale the sway bar bushings. While your at it might as well purchase inner outer tie rods, front lower ball joints. These you can get for $100 on ebay and they work just fine. Then if you really wanted to go at it you could purchase rack bushings, and subframe bushings from Ronnie. These are all polyurethane bushings to by the way. I'm currently completely restoring my suspension right now. You can check out my build thread to check the progress. There alot of other things you can do as well.
I def. plan on clearcoating them.... just waiting for the vht to cure completely. I also plan to upgrade whatever I can while I overhaul my suspension... well idk beyond coilovers. LoL
RazoE;1669552 said:eh, smoked taillights do not look good, sorry..
*sigh I knew this was gonna happen sooner or later LoL... I'm just trying to get the taillights to match my smoked ones up front. If it's any consolation, I do plan on upgrading to 89+ bumper and taillights (a nice set of JDM too
ok off to attempt a coolant change... drain/fill with water/run for 15 min/ drain again/ fill with toyo red. Sound about right? I get the feeling the engine block drain is also in an extremely inaccessible place....
