lithium14;1669049 said:Huh... so that BVSV is it supposed to open when the coolant system is over pressured?... mine doesn't even look like the BVSV's I've seen... except for the blue part, it's like the two long pieces were never there...
lithium14;1669298 said:So... polyurethane bushings from dirftmotion... has anyone gotten them? are they black or red... and does anyone know if they have black vacuum lines? or perhaps the 5/16 push lock in black?? the line from my charcoal canister is plugged LOL... and so the BVSV has nothing going to it... and I wonder how coolant managed to spray out of it... if coolant doesn't pass through the BVSV... does that mean my coolant spray is from something else? anyways... got some more done today, pics are uploading right now
lithium14;1669319 said:yeah the whole set for front and rear
http://store.driftmotion.com/static/i-83126g.php
http://store.driftmotion.com/static/i-83127g.php
ah ... ok I was hoping that was the case but neglected to give the local shop a call before closing time... wait they might still be open *runs off to call
call made, success.. let's see the BVSV I got off ebay for 9.98 but it's used... is that okay?... a new one from driftmotion is like 52 dollars... and it looks like the bottom hole used to be sealed up with some kind of hard stuff... and then after the coolant spray the hard stuff was blown open... which was how i noticed it while looking for the cause to specks of green coolant everywhere
---------- Post added at 07:10 PM ---------- Previous post was at 07:06 PM ----------
OK pics now:
it's funny cuz i got two driver/left side ones... the right side one fit fine... but the left side wouldn't lmao
A little preview... not too bad
All done... awaiting new BVSV, vacuum lines and Apexi power Intake
not too bad... right?
xzeror;1669358 said:your engine bay looks sooooo clean![]()
lithium14;1669340 said:LoL thanks man!! it was worth the effortas for the vht... lessee right now I'm at two coats... i sprayed one, let it dry for a couple hours, then lightly sanded it with 3000 grit sandpaper then sprayed another layer... I'm debating whether to do a third or not... either way after I'm done with the vht, let it dry for 2 days then clearcoat
I started with the center brake light so any early mistakes would be made on that... and boy did I start off early... *blush tbh idk what came over me when I decided to wipe it down with acetone... stupidest mistake ever... but after lots of sanding... it looks pretty good. Also... all the little flecks of dust floating around sucks... which is why i had to sand between coats... to get those off and even out the (what do they call it...) fishscaling? Oh yeah, and then I tried to do my fogs... except for some reason, my clearcoat and vht behave very differently on glass than on plastic... and I can't get an even coat... and then when I try to sand it... they just come off, so... I decided to leave the fogs as is... with just a layer of clearcoat to fill out the bazillion little dents from road debris
About those bushings... it might be awhile before I get them since I'm pretty sure I'm gonna need to have them put in professionally... unless I can find someone to let me use their shop lmao
---------- Post added at 07:30 PM ---------- Previous post was at 07:29 PM ----------
wow I need to limit my use of (...), It's hard even for me to read my last post. LoL!!
RazoE;1669552 said:eh, smoked taillights do not look good, sorry..
