I'm very confident bout my vacuum hose routing
, but the line to my egr is cracked, and since I'm out of 4mm vacuum hose, I taped it up with electrical tape. I would like to replace all my vacuum lines maybe with silicone hose from Hose Techniques. I'm pretty positive about the CPS, I set it just as SA Supra instructed, and I just read Shaeff's article so it is possible the CPS could use a little adjustment, but I have no timing light, so I might have to ask around to see if anyone around here has one. Also your point about the belt is very feasible, I'm going to double check it when I do my retorque this weekend, also with the tensioner, I'm not entirely sure how that is supposed to be set, all I did was pull it so it was tight and then torqued it down to specs. As far as I could tell the two areas where tension should be equal felt about the same. I will also check the tps, and possibly isc... but damn.. I'm reading the tsrm on how to check these things.. and I do not have the tools to do it... need thickness gauges and an ohmeter... *sigh
on another note, I painted the silver corners of my windshied black... looks odd since NOBODY has theirs black LoL
