I have a 7M that I rebuilt and now I am trying to start it. We changed to a T4 67 trim setup and still using the stock AFM. I am trying to start the car and it gets spark and fuel.
My problem is when trying to start the car, it will shortly rev to about 600 RPM and then stall. I checked for codes and I had a code 51 which I fixed with adjusting the TPS. The Idle control valve was stuck when I took it out. It refused to move when I plugged it in and turn the ignition on, replaced motor with one that works.
I had a code 31, which is the AFM. I cleaned the AFM with brake cleaner which messed that one up. I replaced it with a good one, still code 31, this one had an inch hole covered by electrical tape. Still got code 31. I know it is not anything with my harness because it is a brand new Toyota harness, what are the chances of having a defect in the harness that I just bought from them.
Recap:
-Fixed Code 51
-Replaced Idle Control Motor, Other One Refused To Move
-Vaccum Is At 21 When I Do Get It To Idle After Revving And Releasing Throttle Slowly
-Sudden Blimps Of The Throttle Stalls The Car
-Engine Revs Through RPM Range Fine With No Misses
-Currently A Code 31 After The Two AFMs
-Fuel Pressure Is At 38 With Vaccum ( New AFRP With Stainless Steel Hose, Dampner Removed)
What Are Your Thoughts Guys?
Here Are Pictures Of My Setup, Maybe You Can Find Something Wrong With It.
Any Tips?
Recap:
-Fixed Code 51
Any Tips?
