Yup, the Lex AFM that everyone likes to use is from the V8 equipped, 400 series. I suspect you just had some bad luck.
CRE;1459933 said:I wasn't suggesting you test the meter yet again... I meant you might want to test the voltage at the VC pin on the harnes, it's where the AFM gets its power.
CRE;1460241 said:Vc should have 5v or very close.
CRE;1460617 said:Sorry, yes, Ks for a KVAFM (7M-GTE) Vs for a Vane AFM (7M-GE) sorry...
THA is a simple thermistor, ground on one end and ECU on the other. Simply put, the ECU uses a pullup resistor on the other end to create a readable signal between the two. So a ground when the ECU is off and voltage when the car is running is normal.
Not all shorts blow fuses. AFAIK, none of the wires in that harness would blow a fuse when shorted across each other... they may blow other things though (in the ECU perhaps, I don't know how much abuse it can take).
So, check list:
Have you checked for intake leaks (after the AFM)?
Have you checked the ignition timing and the timing belt?
Have you tested for shorts in the harness (you know, is there continuity across Ks and Vc, I would unplug the harness at both ends and then test for continuity across Ks, Vc and E1.)?
You didn't try to clean the new AFM, right (don't if you haven't)?
Did you wash behind your ears?
Do you have access to another ECU?
You said it's barely running.... what precisely is it doing?
I think you need to go through the test procedure in the Toyota Service and Repair Manual (aka TSRM) and test everything... Haynes isn't the greatest.
Here's an online version of the TSRM for a later year Supra, the ECU pinout is different, but the data is mostly the same.
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=FI&P=49
That's literally everything I can think of...
92nsx;1460663 said:^^^ I just found your thread. The AFM didn't do it for you I seeTo bad you are not closer to me, I have another one also sitting here.
Maybe ask / send pm to jetjock and ask him, when he gets time, if he could read this thread and insert his opinion. He's pretty good with the TCCS. Helped me out plenty of times last spring. He doesn't come around the forums much anymore, but he might have more light to shine on the subject.
BoostedRunner87;1460685 said:I do know one thing, it runs alot better AFTER the CEL comes on. it idles smoother and i can rev it up farther until it starts to cut out.
BoostedRunner87;1460685 said:I still wish i had a known good AFM i could test.
jetjock;1460709 said:If it won't go over 3000 rpm that'd confirm Fail Safe but CRE is likely right. It's exactly why I told the OP to unplug the AFM and try it.
Frankly I'm puzzled why this seems so hard to resolve. Ks is easily tested with any decent DMM and if it checks out the causes of code 34 are well known.
