akito said:Well, i want to know that if you go NA-T with NA electronics, what are they? Same old MAF? Distributor with plug wires? Wat about injectors? Did you guys rebuild before that or just added on all those stuff?
s383mmber1 said:You can literally simply add the turbo, manifold, and intercooler to it and it will run.
Will it be fast? Yes
Will it be cheap? Yes
Will it be reliable? No
Will it last long? No
Ma70.Ent said:Do you have actual experience with this?
Im running with GTE electronics, 440CC injectors, turbo AFM, NA cams, Turbo manifold, CT-26, open BIC DDP, SAFC, Wideband, and a barage of other misc things. Im hoping at 10PSI for around 300 HP, and at 15 PSI 360ish. Keep in mind htough, this is with higher compression, so tunings gonna be a bitch
Lemme know any questions you have!
osiderida06 said:well my plan for the first upgrade after i get the turbo on is a little air and fuel upgrade. Ill be getting the lexus afm with some 680cc injectors. I was going to get the 550's but the place on here where im going to get them from only have 580's and 680's flow tested. So i might as well get the 680 since there the same price. Engine internal upgrades will come later in a couple of months or so when i get my either my 57 trim upgrade or a t4. How much boost will i be able to push with the ge electronics still installed? about how much hp? And will this be any different if i switch to the gte electronics? What are the advantages of having gte electronics over NA?
On the stock headgasket, with stock NA electronics, on a stock turbo, i wouldnt suggest going over 7-8 psi. IMO its DEFINATLY worth it to upgrade the electronics, it doesn't cost to much more, and youll be mega pissed with you put a whole in your piston. Also, the headgaskets not hard either. And wont cost to much.osiderida06 said:How much boost will i be able to push with the ge electronics still installed??
Burntz said:I like this thread![]()
osiderida06 said:Well i see everyone posting up fs items to convert to gte electronics. Is there anywhere where i can get this stuff as a whole to save money. Because buying them seperatly just seems to add up way to quick.....and im planing on a getting a mhg and a 57 trim upgrade with 680cc injectors. What do you guys mean getting rid of the afm? what do you use in its place? any other basic information would be grealty appreciated...And yes this is defiently becoming an excelent resource...thanks guys
