7mge-T
osiderida06
45
Chillicothe, Oh
an inexpensive GM MAF OR speed/density (this eliminates the need for a MAF).
What excatly is a GM MAF or speed density. I know all these questions but you guys really are helping me alot. I have learned more about turbos set ups then i have ever learned about anything in the past 48 hours. I just need the info to keep on coming. Because i want to be able to get a nice setup going as soon as i get the turbo kit. Im going to call the guy tomorro again and see whats taking him so long to get it to me. He lives in town wher ei live but i guess he is just a busy guy.
So if i get maft pro i can run an intake right into the turbo and not have to have a afm? Is there any tutorials or anything on the way of tuning the car in this way? I looked in the piggy-back section but there wasnt any good info on how to di this stuff that i could find!
And what kind of boost controler do you guys suggest for this first set up im going to do? And how does boost control work? Just turn it up or down depending on the setup you have? Just think of this as adding to the wealth of information this thread will have for the newbs! Like me! LOL
lifted
157
memphis
osiderida06 said:
well my plan for the first upgrade after i get the turbo on is a little air and fuel upgrade. Ill be getting the lexus afm with some 680cc injectors. I was going to get the 550's but the place on here where im going to get them from only have 580's and 680's flow tested. So i might as well get the 680 since there the same price. Engine internal upgrades will come later in a couple of months or so when i get my either my 57 trim upgrade or a t4. How much boost will i be able to push with the ge electronics still installed? about how much hp? And will this be any different if i switch to the gte electronics? What are the advantages of having gte electronics over NA?
for one you cant use afm when your ge has a maf, you will have to have the gte electronics to use the lexus afm.
osiderida06
45
Chillicothe, Oh
HAHA that is good...I can take that off the list.. I can get some 680cc injectors for 470. They are mfg by delphi. Flow tested an all...includes injectors, rings, clips, shipping, and paypal fees... So my first little setup before i do my rebuild will be 680cc's, maft pro, and a 57 trim upgrade? will this do ok till i get the money together for the rebuild? And ill prolly throw some Aems cam gears in there after i get the set up running good! will this keep me happy till i get the rest?
lifted
157
memphis
im getting the stuff together to turbo my na as well. i was going to do it with out the gte electronics, but after reading this thread i think i will go ahead and get the gte electronics.
Sl1dewaysSupra
Destroyer of FWD's
Mar 14, 2006
690
Colorado
Seeing CRE's MAFT PRO setup is what convinced me to go turbo. Allowing me to stay with the GE's electronics saves me alot of headaches. (From what I gathered swapping to GTE's electrics is pretty much plug and play, I just didn't want to trace wires etc.) Plus like CRE said I didn't like the idea of having a turbos ECU running a higher compression engine, too many "what iff's" for me. The tuning capabilities of the MAFT Pro are a better option for me than the GTE's electronics plus a SAFC. Just my thoughts.
need new tires
rubber slinger
Nov 10, 2005
173
Dayton,Ohio
Sl1dewaysSupra said:
... Plus like CRE said I didn't like the idea of having a turbos ECU running a higher compression engine, too many "what iff's" for me. ..
i dont think the higher compression is an issue. go to the basics what is the turbo doing? raising the compression. the turbo ecu is not even skipping a beat with my motor starting @ 10:1 CR then factory boost.
as for the maft-pro if is works i would say atleast an additonal 20-40 hp just from the n/a fuel maps. i am always looking for a better route, i tried n/a electronics and it wasnt for me.
-shane
osiderida06
45
Chillicothe, Oh
quote - Is there any tutorials or anything on the way of tuning the car
I need some adivice on how tuning works with themaft pro..I have never tuned a car or even watched some one tune one? Is there anything out there to help me out with this..I have a laptop so if i can learn how to do i would call that money in the bank!
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I'll try to keep this simple: (and yes as such I'll be omitting a fair amount of info and possibly leaving assumed relations/comparisons which aren't 100% accurate)
A MAF is a Mass Air Flow sensor. It's used in measuring the MASS of the air entering the engine. The differences between one of these and the N/A's AFM (Air Flow Meter, a generic term) are numerous. There is no physical valve which the incoming air has to move for measurement. The GM MAF (a "hot-wire" type meter) is a very common sensor and as such it's CHEAP. It's less sensitive to disruptions in the airflow and foreign materials then the GTE's Karmen Vortex AFM (which is used to calculate mass). They're available in numerous diameters including 3.5". The large diameter and less restrictive inlet buffer make it a very popular choice. This is what I'm running in my N/A at the moment.
The 7M-GTE employs a Karmen Vortex AFM. This system is rather complex and can fail if improperly handled or subjected to certain conditions. The Karmen Vortex system uses an inlet screen designed to create a vortex from the incoming air. This vortex is monitored optically and the mass of incoming air is calculated from the data provided. If the optics should become clouded (due to oil or similar contaminates in the air) or if the inlet screen should become damaged the entire meter can fail to relay enough usable data to even limp the car home.
Technically, the N/A has a VAF (Vane Air Flow meter). The meter works by employing a spring loaded trap door (aka flapper or valve) to calculate the volume of air entering the system. Another way of measuring air flow, different physics and math. ;)
Speed/Density (aka MAP) is a system which measures the pressure and temperature of the air within the intake manifold. These datum are used to calculate the quantity of air within the intake. This system is popular as it places extremely little material in the path of the incoming air and as such creates the least resistance of the four options mentioned here.
In order of restriction (lowest at the top) we have:
1) S/D or MAP
2) GM MAF
3) KV AFM
4) VAF AFM
You can find out more specific data on air flow meters here: http://www.autoshop101.com/forms/h34.pdf
Yes, that's speed/density. There are some walk throughs, but unfortunately speed/density can be a tricky system to get just right and the settings can vary heavily even when installed in two of the same cars.
Setting up the MAFT Pro for MAF Translation (get it? MAF-T ;) ) is easier but it does impose some restriction. Plenty of turbo guys use this system without issue and there's no reason you can't.
By the way, you can place a GM MAF either before or after the turbo. The latter is referred to as a blow-through configuration. The benefit to this is greater accuracy and if you blow an IC pipe/hose the car will still run well, you just won't have any boost. The same goes for S/D when you want to be sure if something goes wrong you can still get home.
osiderida06 said:
And what kind of boost controller do you guys suggest for this first set up im going to do? And how does boost control work? Just turn it up or down depending on the setup you have? Just think of this as adding to the wealth of information this thread will have for the newbs! Like me! LOL
Boost control uses a mechanical valve to control the amount of pressure seen at the wastegate. The waste gate is a valve which allows exhaust gases to bypass the turbo's exhaust impeller and stop/slow the turbine's movement. When you add a boost controller (manual or electronic) it's important to remember that it won't be able to cut your boost to any level below the wastegate's actuation level. In other words, if you have a wastegate with a 7psi actuator the boost controller won't allow you to lower that amount... it only allows you to up the boost.
Manual boost controllers (MBCs) are rather simple valves, they hold back the pressure which would normally actuate the wastegate until their pressure requirement is met. So, your 7psi actuator won't budge until the manifold is at 14psi which is when the MBC opens up and allows the wastegate to open up.
Electronic boost controllers (EBCs) come with a variety of features. Some systems let you set different boost level depending on certain criteria (such as throttle position and engine speed). Some have inputs for a second tier as well... this is nice for a daily driver. You can set a lower level for day to day driving and add a switch to the dash which activates a secondary more aggressive tune and boost routine. How these function and how they are adjusted depends on the device.
What? I don't think I understand what you're saying.... actually I'm pretty sure of it.
AFM is an acronym for Air Flow Meter, a generic term nonspecific to the type of sensor. MAF indicates HOW the air is metered (which is to say it's measured by its MASS). Technically, the GE uses a VAF (Vanee Air Flow Meter) and the GTE uses a KV type sensor to calculate mass.
Also, it should be possible for an N/A running a MAFT Pro to use either the 7M-GTE or the Lexus AFM... but why?
I was referring to the timing map that CRE stated. But I totally understand what you are saying.
Yes, the turbo effectively increases both displacement and compression. BUT, keep in mind that the GTE also uses less aggressive timing advance maps. I don't know about the MKIII but I do know that on some turbo vehicles the timing map is scaled back further depending on boost levels.
Sure, you can pull 5º of timing or more, but why take it off the low end as well if you don't have to? It's not a big issue, just something that I would like to be able to tune in the event I decide to go with an aggressive tune.
I do agree though, a turbo on stock N/A electronics isn't for me either... but mine aren't quite stock. The MAFT Pro has given us an option which really bridges all the gaps quite well. Don't get me wrong, some parts of it have one hell of a learning curve (I'm trying to work through some of this right now). It's not the easiest or prettiest system. However, given everything it's capable of I really don't see the reason to go through the hassle of swapping in $500 worth of used parts and still probably needing to add a fuel controller (and depending on your needs a boost controller and a timing controller).
This is one of those things where everyone has to make up their own mind. There are ups and downs to each solution available.
CRE
Oct 24, 2005
3,485
Denver, CO
I need some advice on how tuning works with the maft pro..I have never tuned a car or even watched some one tune one? Is there anything out there to help me out with this..I have a laptop so if i can learn how to do i would call that money in the bank!
I honestly don't know of a good online tutorial for complete novices. I'd be interested in seeing one though.
For "tuning" there is another item which hasn't been discussed at length just yet. A Wideband Oxygen sensor (WB O2) and controller is a must for automotive tuning.
The stock oxygen sensor in the MKIII is what's commonly referred to as a narrow band sensor, it's got a small scale over which it relays information about the vehicle's exhaust. From this information the engine will either add or remove fuel. Wideband sensors (and their controller) employ a wider range of feedback and generally provide a more stable stream of data. Stoichiometric (the "perfect" mixture: 14.7:1) is where the engine is burning 14.7 units of oxygen for each individual unit of fuel.
While an Air to Fuel Ratio (AFR) of 14.7:1 is considered optimal there are numerous circumstances where it is not desirable. To understand these you need to understand the implications of running "rich" (more fuel than necessary) or running "lean" (using less fuel then is optimal). The biggest consideration is heat. The less fuel the hotter the combustion. Run lean at the wrong time and you can cause serious damage to your motor. If you run rich the combustion will generally be cooler, but you're not making as much power as you could be and you risk damaging the O2 sensor and the catalytic converter. Either can contribute to various forms of pollution as well.
With the implications understood you can (most cars do) run the car on a leaner mixture while driving at a low and steady load. This will increase engine temps but also improve fuel economy. If you screw up and go too lean or specify too broad of a range for a "lean cruise" you can put your engine at risk.
Intentionally running rich can help in two ways, decrease temps while running the engine hard and it can serve to stabilize the combustion by extending the time it takes for the mixture to burn. The downside to this again is you loose potential power.
Wiki: http://en.wikipedia.org/wiki/Air-fuel_ratio_meter
I'll apologize for any errors or omissions in advance. ;) I'm tired.
osiderida06
45
Chillicothe, Oh
WOW man..i go to make me something to eat then take a shower and come back to this. I just want to thank you cre. This is excatly what i have been looking for. I think you made it as clear as it could possibly be. Im now going to stick with the NA electronics for a while. So i need to pick up a maft pro and an electronic boost controler. I want to be able to set to different setting for boost. Like you said, that way i can have one setting for cruising around and one for racing around. LOL. One of my jobs are about 15-20 mins away and it would be nice to have a low boost level for driving there until i can get beater DD.
What type of electronic boost controler do you guys recommend for a decent price. Are they car specific or will any boost controler work on any turbo car? I found this one on the bay http://cgi.ebay.com/ebaymotors/Gred...tegoryZ33742QQihZ019QQitemZ290127219501QQrdZ1
Anyone know of any one who has maft pro for cheap?
osiderida06
45
Chillicothe, Oh
does it have 2 different setting on it? i mean if it dont im not going to go buy an ebc. Im just curious. Is there a link somewhere to any website that shows everything the maft pro does (a break down of it)?
CRE
Oct 24, 2005
3,485
Denver, CO
Yup, it's got an Aux mode. ;)
BTW, don't take my word for gospel. There's plenty that I don't know and I've been wrong before..... once. :evil2:
If you want a preview of what you're getting into you can look here: http://www.fadingworld.com/Supra/MAFT/Manual 4.80.php
It's a basic list of v4.80 of the MAFT Pro's software settings.... part of a new project.
The official MAFT Pro forum is at www.fullthrottletech.com
If you want to buy one send a PM to drjonez. He's a vendor, and had a lot to do with getting the MKIII supported.
osiderida06
45
Chillicothe, Oh
well i just got done reading your write ups. I just want to thank you for being the ginny pig. Sounds like you had a heap of problems getting it working correctly. Im not going to be hooking it up by myself hopefully. I have a friend who is a mechanic and tuner freak for sure. So im going to see if he will help me out. But im not the type who just lets some one do it for me. He will be showing me how to do it. So the next time i will be able to do it on my own.
