kamikazemkiii;1341196 said:Holy Fuck that 2nd vid is kick ass
cams + single turbo = priceless XD
Alec;1340890 said:I thought either valve or injector, but idk. Should I worry about it?
87M-GTE;1340092 said:7M Grunt > 2JZ purr>1JZ scream
1JZ chainsaw rev>2JZ rev>7M rpm increase (AKA torque)JPsToyota;1340717 said:fixed :bowdown:
GC89;1341225 said:Most likely valve tick if you are running stock injectors, 550s+ are a little noisy. The 7M has a somewhat tappy top end as is but I would recommend checking your valve lash as needed maintained is often skipped on these cars.
Fixed![]()
Alec;1341329 said:I think it may be injectors because it doesn't go away when the engine is fully warmed up.
rayall01;1341357 said:If a valve is too loose, it will make noise all the time, hot cold, whatever.
JDMMA70;1341373 said:I havent had time to check mine yet but i do know two other people who got their heads done by the same place their valve clearances were out of spec, so its safe to say its probably on the loose side considering they had to get thicker shims.
Depending on how many valve need to be reshimmed check first then add up cost of which ones you need.
Alec;1341401 said:Uhh, I don't know how to do that. Wouldn't fuel be spraying all over the place?
7M-KDL;1341415 said:no, unclip the electrical wire...dont take out the injector..
