7M Sound?
87M-GTE
Slow
Sep 12, 2007
1,705
Milwaukee WI
Moy
It's broken...
Aug 6, 2008
2,432
Beach Park, IL
kamikazemkiii;1341196 said:
Holy Fuck that 2nd vid is kick ass
cams + single turbo = priceless XD
That guy is a friend of mine. He's running an 88mm turbo on there right now. Crazy fast and LOUD AS F***!
GC89
1J-THIS
Jun 13, 2007
938
Spokane, WA
Alec;1340890 said:
I thought either valve or injector, but idk. Should I worry about it?
Most likely valve tick if you are running stock injectors, 550s+ are a little noisy. The 7M has a somewhat tappy top end as is but I would recommend checking your valve lash as needed maintained is often skipped on these cars.
87M-GTE;1340092 said:
7M Grunt > 2JZ purr>1JZ scream
JPsToyota;1340717 said:
fixed :bowdown:
1JZ chainsaw rev>2JZ rev>7M rpm increase (AKA torque)
Fixed ;)
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Fixed ;)
So you think it's my valves? Should I worry about it?
JDMMA70
2,550
Houston
That just mean they may be out of spec (shim wise) you just need to check and re shim if needed, i havent done it yet because im short on time. I dont see it hurting anything other than maybe making parts wear out faster.
JDMMA70
2,550
Houston
I havent had time to check mine yet but i do know two other people who got their heads done by the same place their valve clearances were out of spec, so its safe to say its probably on the loose side considering they had to get thicker shims.
Depending on how many valve need to be reshimmed check first then add up cost of which ones you need.
Alec
SP Tuned
Apr 6, 2009
712
Illinois
Well, how do I know if it's injectors or valves?
JDMMA70
2,550
Houston
The clips are on the intake side you'll see them they should be red and grey/white, no it'll just kill fuel to that cylinder. You can also take a screw driver put it to your ear and probe around.
sethron71
Authorized Vendor
Jul 19, 2005
871
Las Vegas, NV
www.SethIngham.com
My new setup has a lot more rasp.... Tubular exhaust, medium single, and full exhaust. I will make a video. I always like the sound of a fairly stock 2J with just exhaust and IC setup. Decently quite but a noticable note! And mine is a good bit quieter now but has a nice rasp as the RPMs come up! I will get a vid asap!
Seth
