7M-GE + Supercharger?
Kai
That Limey Bastard
There *has* to be room to put it somewhere and NOT remove any of the A/C, Power Steering etc. What about custom fabricating brackets for accessories? That way, you could bunch stuff up and shunt it around whilst still having room for the supercharger ;)
Wreckless
Master Lurker
1TuffSupra said:
the NA non-vvti 2jzge does have a distributor but its highly unlikely that you would be able to use the 7ms electronics on a jz. If it were the case Im sure a whole bunch of people out there that swap the jz (1 or 2) wouldnt go through all the trouble of swapping out all the electronics. The VVTI equiped jz does not use a distributor
The 7M-GTE CPS works on a 2JZ-GE head where the distributor mounts. Many NA-T guys use it for an ign trigger on a standalone and others have used complete 7M-GTE ECU's, wireharnesss and ignitors but with piggybacks for fuel tuning and it works well especially if the GE block has dropped compression via thicker MHG or custom pistons.
The reason that its not a common thing in say a MK3 is you still need to make all of your hard parts JZ compatible and you still have the crappy intake manifold pattern.
935motorsports
San Diego, CA
You can make a custom intake manifold, with a supercharger as part of the assembly. The problem there is that the alternator is in the way.
There are many ways to do it, it is a matter of what you can afford.
If someone handed me a gold card and said "make me supercharged", I'd have them a setup in a week.
The problem is, the people that have that kind of cash, buy a turbo car, or do a turbo swap.
mmarkk
ShoarmaTeam Member
Apr 12, 2005
89
The Netherlands
RIPDOTCOM
157
Tallahassee, FL
I'm gonna start a new thread about this. I have first hand used his products (not this one) and attest to the quality of the product. I was making 4psi on an escort GT (1.8BP mazda engine, same as the miata for those of you not familiar) THis looks like a complete bolt on package that should only take a couple hours to install. Best part is that there will be no fab work. Just put it in with good fuel management and a small intercooler and it will rock your socks off.
http://www.boosthead.com/home.php
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
you can fit it, but you would loose something in the process. you could loose the PS or AC, if you move the AC, then you can relocate the alternator down lower, then mount the SC up top where there is more room. this idea would probably be best, running maf-t pro in speed density to free up more room, pipe it down to the FMIC, and then over to the stock intake location, keeping ACIS and everything, with less fab.
corylee316
until it goes boom
Aug 17, 2006
125
Moscow, IA
Draw up the plans. My ps leaks faster than I can add fluid and my a/c clutch melted itself to itself a long time before I got the car. I already have a more basic car than almost everyone here. I have no plans on fixing the a/c and I would just as soon replace the ps with a manual unit as I have grown accostom to turning two hand style.
935motorsports
San Diego, CA
There is no kit, that is just an example. Supercharger kits tend to run $4000 or more. You can buy a whole turbo motor for less then that, including installation. Even a turbo kit, including all new parts, and a new oil pan is less.
However, if you have $4000, I'll be glad to design you a bolt on kit that uses factory mounting points and retains AC. Seriously, we have always wanted someone to do an SC, but nobody has the money to play hardball.
You can tell that one pic is chopped because it is the same setup from another picture. The ribbed part of the picture is all choppy looking. They just pasted it over the top of a turbo motor.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
im willing to be a test subject and help you promote the products, yor 4k, ide hope that i would get a piggyback pre programmed, and throw in some modded headers. pm me and ill give you my number, and we can talk in person.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
i wish that there was a place to put a roots or twin screw SC in the bay of a supra. im already ditching my AC, PS and heat so thats a little more room to play with.
one idea that still seams plausable is removing the AC, putting the alternator where the AC was and mounting the SC where the alternator is.
shit, ide run with a DSM style bulge in my hood, or a raised cowl if i could fit a m-90 in that bay.
2slow4you
19
WV
It's fiesable to do. If I had a junk SC I could start the fabbing process. Start out fabbing with steel plates and such then send it to someone to do nice watercut aluminum flanges and aluminum tubes etc.
Try to make a system where it would run on one of the existing drive belts.
If anyone has a pull a part that has a broken SC cheap LMK I might be able to afford it...Hell even a shell with a snout would work for the general purpose. I've got a spare motor or 2 layin around :)
