Okay, after replacing the clutch last year (ACT stage 3), I got some issues, which seem to fit with a walked crank, or at the very least, rod knock.
I've got another 7M-GTE lined up, and should be here before the weekend, which I want to get ready to drop in.
In preparation for this, I've ordered a MHG (Titan 1.4mm), ARP head studs, and a complete gasket kit. My hope is that I can get the head resurfaced and lap the block to install the MHG and be good to go. Is it realistic to expect to be able to lap the block (Assuming that the block surface is good with a straightedge) with the pistons in and get a MHG to seal? I'll replace the manifold gaskets, valve cover gaskets, front and rear main seals, oil pump drive seal, and whatever other gaskets I see when I pull things apart.
Also on the way is a new timing belt and oil pump. I'm picking up a DM oil pump hose locally, too. I'll be re-using the alternator, starter, turbo, injectors, AFPR, wiring harness and a few other things from my current engine when this is ready to go in.
I don't think that I have the budget to be replacing bearings and getting associated machining done, which is why I had thought that a different block would be a good place to start. I also plan to eventually repair the block that is in the car now, but that's likely to take some time. It'll be on my engine stand for a long time, I think.
Anyway, given that I'm putting this engine together on a tight budget, is there anything else that I should do while I've got it open?
