Looks like they've relocated the offending rivet on that gasket Dan, it was at the front opposite the oil drain behind the waterpump.
Dan_Gyoba;1827921 said:Just to re-cap:
First of all, thanks to those who provided helpful advise and information, notably IJ and suprarx7nut, though not limited to them.
Project started as a "simple" swap-out, with necessary machining only to pretty much a full-on build. Well, that's how it is, and there's my hobby budget for the year.
I didn't get an answer about useful support electronics. As it sits, I'm using the original ECU with the Lexus/550 modification, and that's it. I know this doesn't leave me much for tuning options other than the adjustment screw in the AFM and base fuel pressure with the AFPR. I like the ability to adjust stuff, and it would be nice to be able to go MAP. I'd consider the MAF-T Pro, though it probably won't be this year. Anyone have opinions on this, or anything else which would be good?
Anyway, I will be starting a build thread when I start the tear-down.
suprarx7nut;1827979 said:Happy to try and help.
For piggybacks, I've been meaning to really dive in and write-up a good comparison, but I haven't had the time. As a very general statement, MAFT-pro will offer more tuning options and features, but it's rather cryptic. You'll have to do some homework before you even know what the display is telling you. SAFC is cheaper, easier to use, looks more modern, but will not allow you to ditch the AFM and you can't go speed/density like you can with MAFT-pro. I couldn't give you a list of things the MAFT-pro can do that the SAFC can't, but I'm sure you could come up with a quick checklist.
A couple things MAFT pro can do that make me lean their way:
-Tip in adjustments (I'm not sure in many other piggybacks allow this. Maybe they do, i dont know)
-electronic boost control with GM boost solenoid(I'd be able to ditch my ProfecB and clean up my dash)
-MAP sensor in place of AFM (speed density. This also allows you to run your BOV to atmosphere and impress high-schoolers and questionable women) http://en.wikipedia.org/wiki/MAP_sensor
-As I understand, the MAFT pro will also allow a wideband to be used as feedback while tuning. Datalogging in general seems to be much more capable with the MAFT Pro, but that's just a feeling I'm getting while I begin my research.
Yep old one will be fine!Dan_Gyoba;1836137 said:@AJ'S 88NA: Yes, I know about the one on the block, it's the one behind the cam gears on the head that I wasn't sure about.
@IJ: Thanks, I think I would have missed that. I'm going to change the timing belt tensioner anyway, but the old one should do as a placeholder for the machining process, right?
@Suprarx7nut: This is what I was thinking. Since I'll be going for an overbore, and have to buy new ones anyway. NPRs are $120, and the Probes are $440. The next step would be the $680 Arias. One of the key questions though is rods, since I can't re-use the ones that I have.
Well, tomorrow, going to have a conversation with Aaron at Driftmotion about oil filter relocation and oil cooler stuff. I know he's got a vested interest in me buying stuff from him, but I'll ask about pistons and rods. one thing about the Probes that kind of bugs me is that the pics don't show them as dished though they do have reliefs for the valves. So long as they will result in close to the correct compression ratio it should be fine though.
Dan_Gyoba;1836137 said:one thing about the Probes that kind of bugs me is that the pics don't show them as dished though they do have reliefs for the valves. So long as they will result in close to the correct compression ratio it should be fine though.
Dan_Gyoba;1836702 said:Well, had my conversation with Aaron. The Probes are indeed backordered, so the next choice would be the Arias, but at $680, this is starting to tip the money scales further than I wanted. I'm already way over initial budget (Gee, I wonder why...)
jonahs_supra;1836758 said:aaron sent me a email yesterday on pistons...
he said they should have more probe pistons next month
i asked about the standard bore set
im suppose to call him today to varify
