.68 housing to small for 600-700 whp??
mk3-4-me
669
Milwaukee, WI
No why would I try and push a stock bottom end to 600 whp? Lol
only thing stock on my car right now is my valve train. But I'll be getting springs n cams eventually.
It's a built 7m, will be meth injection, and on Stinger EMS.
mk3-4-me
669
Milwaukee, WI
And Harley. 11 - 12 psi isn't going to get you close to 400 hp. On my 6152 I made 391 rwhp and 377 torque at 15 psi.
Different setups, but 12 psi will not cut it.
IBoughtASupra
4,455
Queens, NY
Mr Bojangles;1818770 said:
This thread took an encouraging turn. I was expecting to struggle to get to 600 on the 6266 with a .68 and E85, but I really don't want to push the stock bottom end past that anyway. After it's built next winter and has higher compression I will swap for something bigger.
On your 2JZ, your good up until 800. Stock block is fine with 600.
mk3-4-me
669
Milwaukee, WI
I know. But Quake, as I'm sure you guys know of his crazy 7m, sold me his stinger. And he's going to help me get there.
I'm not worried about getting there, I'm just worried about the housing. I don't want to have to pull it back off after I find I can't hit my mark. Lol
what's the spool compared between the .68 and .81?
harley1985
117
killeen tx
lol well ok, i gotcha on that, i can always raise the psi, wat i was really asking is does that even sound practical? or should i opt to get a smaller turbo? and yes i also would like to know the spool comparison between a .68 and a .81 or even a .83 :) also wat set up were you running so maybe i can compare and see where i should be.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well I was going to post this befor but the motor changed abit it built 7m on basicly 5 pistons
mods one fucked piston and 3 other damaged piston's
motor mods
crank scaper
je piston thermo coated
eagle rods
deleted oil squrters
and 81 hot side
20 psi
my old map was 24 psi at 585
ant this was not a good tune eather even resalted in damaging my motor
K_SHAN
don't taze me bro!
Jul 3, 2009
357
eagle, IDAHO!
I have a t4 76mm with a .68 lol I'd hope it would make 700! (I ran it on my 7m at 30lbs, but never dyno'd) even though it would probably peak and drop out. I just ditched it for a 71 .81
NashMan
Aug 5, 2005
4,940
17
Victoria BC
mk3-4-me;1819695 said:
Why did you delete the oil squirters?
And when did you see full boost at with the .81?
because forged piston's oil jetting is some what not needed if you have a proper tune, now how long will the motor's ring's last is the big question that I can not answer
since all the pistons heat is transfer though the rings
technically since the dawn of time you pistons have bean cooled form fule/air and the over all temp of your motor
but in the late 80's the some companies started to add in oil jetting on turbo cars to help displace heat because cast pistons can not handle heat all to well nore dis pate the heat to the ring to the cylinder ways properly and over all relibilty 500.000 mile ect
further more oil jetting gives off alot of drag on the under side the piston witch reduse's horse power and rev speed
now is this for you you have decide? there pro's and cons of keeping them and deleting them read up on ask question and you find out if ya wana do it just do not do it with a cast piston or Hypereutectic pistons
for this time around I am going to be slotting my lower connecting rod's to provide more oil to my walls to prolong my ring life
ATL88Supra
The Asshole
Jun 22, 2007
497
Atlanta, Georgia, United States
the amount of power loss and drag created by oil is negligible
the pistons may be forged but who gives a fuck put the jets back on and have peace of mind
by removing them you are only asking for problems
if you want to make it go faster put on some cams (with valve and springs and shit) put on the correct turbo and stop trying to shortcut
also i am sorry but IJ is correct and even more so for the 7mgte listen to him, he has been there and he knows alot more about the 7mgte then you do
91Supra313
1,062
Clarksville TN
It seems to me that alot of the people that have not had to rebuild their motors a few times from trying some of these short cut ideas and plans, are trying to get some ideas for short cuts. If you want your motor to last, listen to some of the people that are telling you correct things. If you enjoy wasting money then buy 2 or 3 different turbos until you find the one that will work with stock stuff. If you want to do it right then build it. Don't rush because you want 600 and think that this one turbo will do it. There is a ton more into it then just a turbo that says it can push 700Hp.
Just to clear this one up I am fully agreeing with you ATL, and IJ.....
ATL88Supra
The Asshole
Jun 22, 2007
497
mk3-4-me;1820189 said:
^ agree about the oil jets.
And I don't think anyone was disagreeing with IJ. Lol
But it seems like it can be done with a .68 housing.
oh sure it can be done, but it wont last long
lol also i was agreeing with the fact that IJ said it was not easy to get reliable 600hp and i was pointing out that its even harder with a 7mgte
but ya
NashMan
Aug 5, 2005
4,940
17
Victoria BC
also i am sorry but IJ is correct and even more so for the 7mgte listen to him, he has been there and he knows alot more about the 7mgte then you do[/QUOTE
Do your reserch then you will know
now is 600 easy well kinda if you have a good tuner and all the stuff to make it work
700 well that 2012's new hard limt back in the day like 2004 500 was hard
over all you can hit any number it's just going to cost you and in most case's it's all ways the tune
ps you be suppried on how much drag is on piston and is very comon in the honda world 3sgte world ect do the research so you under stand how it works before saying stuff
mk3-4-me
669
Milwaukee, WI
but ya
Why wouldn't it last long?
NashMan
Aug 5, 2005
4,940
17
Victoria BC
like any performance motor you throw long lived reliablilty out the door
but noway days efi system out there are getting better and better so stuff can be push and monitor alot better, but this is only as good as the ecu mapping and it all and resevieing information alot more clear infromation
and over all head desigh and piston
