.68 housing to small for 600-700 whp??
ATL88Supra
The Asshole
Jun 22, 2007
497
Atlanta, Georgia, United States
NashMan;1820276 said:
ATL88Supra;1820168 said:
the amount of power loss and drag created by oil is negligible
the pistons may be forged but who gives a fuck put the jets back on and have peace of mind
by removing them you are only asking for problems
if you want to make it go faster put on some cams (with valve and springs and shit) put on the correct turbo and stop trying to shortcut
also i am sorry but IJ is correct and even more so for the 7mgte listen to him, he has been there and he knows alot more about the 7mgte then you do[/QUOTE
Do your reserch then you will know
now is 600 easy well kinda if you have a good tuner and all the stuff to make it work
700 well that 2012's new hard limt back in the day like 2004 500 was hard
over all you can hit any number it's just going to cost you and in most case's it's all ways the tune
ps you be suppried on how much drag is on piston and is very comon in the honda world 3sgte world ect do the research so you under stand how it works before saying stuff
i found it hard not to say something nice about your last statement so i am going let you do whatever you want
do champ
if you want to hit your goal you are going to need a t70-71 that will also give you more room to go higher 800?
mk3-4-me
669
Milwaukee, WI
i deff wont need a t71. a 67mm will get me 700, and just into the 800's if needed i bet.
But ill see what happens. Im going to want to rev higher, so i might just get the turbo with a .68 and just order a .81. Since i hear the spool isnt much worse with an .81.
ill see im stil ldoing some research from all the forums.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
do champ
the newer CEA t70,t67 can both do 600 to 800
they don't even list my turbo any more but it was rated at 680 and I bet I could sqeewed 40 more out of it at full song 30 pounds
