600hp 1JZ supra vs 600hp Gt500 vs 650hp C6 z06
Dec 31, 2010
216
IL
BoostMonger;1906807 said:
#supraproblems
Sent From My HTC One S using Tapatalk 2
HAHA! Nice
Albert your 1J Astounded me. I have a buddy with a terminator and I will make a vid like yours, once tax returns get me the GoPro3 ( :)
flyjum
75
Mesa AZ
Hmm wonder how much the diff was moving with load or on deceleration
If it was moving a good amount that could be what blew the trans from throwing the driveshaft off angle
turbodriz
mk3 onwer
Feb 25, 2006
471
newyork....N.c
You are right. It happens in our heavy haulers up here in N.Y. Drive shaft doesn't spin true and wipes out bearings and other things in tranny and rear end.
88mk3supra
7M DEMON
May 23, 2009
390
Clayton,Ohio
nice vids and god that 1jz sounds great albert! what turbo and exhaust setup are you running? and im guessing your revving to around 8,000 rpm? nothing better than a jz at high rpm's. great car you have albert
BoostMonger
PUSH IT TO THE LIMIT
Sep 5, 2011
880
Shadows of Utah
Albert;1908161 said:
Instagram?
Still a small ar housing not a 1.00 like you see on most supras
Ya Jeff posted a picture of the dyno sheet. What size housing is it? .8x? Still a crazy drop off
Albert
May 13, 2009
1,710
Tempe, AZ
It's really not that bad. It's bad scaling makes it look bad and that was trq.
Here is a pic:
BoostMonger
Sep 5, 2011
880
Shadows of Utah
Ya there we go, the one I saw must have been squished horizontally. Did you do a pull at peak boost without nitrous?
BoostMonger
Sep 5, 2011
880
Shadows of Utah
Albert;1908248 said:
I was totally kidding about nitrous. No nitrous at all
-__- well I believed you crazy man. I didn't think 30 psi on e85 would go quite so high. More props to ya
Albert
May 13, 2009
1,710
Tempe, AZ
Thinking about doing like a 50shot at 3k, the turn it off once boost hits. should give me a better powerband
BoostMonger
Sep 5, 2011
880
Shadows of Utah
I pmed you about a qsv set up for my car but you never wrote back
In for more domesticated violence. You should be one of the fastest out there the next time you go. I'm not sure you'll be able to hang with the vette, even with seven hundred horses, but it should be a great race.
