Ok so i mounted the first side today with the 6 pot monsters. All was going well until i mounted the wheel. It won't clear the caliper. The way i see it is i have two options. I get wheel spacers to push me out at least 5mm or i start grinding on the lip of the caliper. It seems worse on the ends of the caliper, i think the middle would only need a few mm shaved off. The 14" rotors have loads of space around the wheel. Must be the style of the wheel as the spokes slant inward.
Open to suggestions guys. I don't want to weaken the calipers by grinding them if that is what will happen. Not to keen on spacers as the wheels fit nice as they are..
Here are the pics, me a and my mate recon that a 5/7 mm spacer should be enough to clear the caliper. Don't really want to be grinding anything.
Quite clear where the problem is as the new paint is already scraped off.
