Adjuster
I choose the wheels I have based on them fitting the brakes, and that they are very light weight. (Your 0Z's are about 30+lbs each, these are about 17lbs.)
That is quite a bit of unsprung weight. Mine are 18's, but the spoke design allows for much more clearance.
Interesting to see there are quite a few Precision setups out there. How many of you guys have them with the front and rear brakes?
Fronts with the wheels in place.
Rears with the wheels. (These use steel hats, so the stock parking brake works in the mounting hat.)
