The deck height is the same between the 5m and the 7m, the 5m crank with the 5m rods is a direct swap, this is why I kept asking how much power they will hold .
You would use the 7m pistons on the set up as they fit directly on the 5m rods. 2j, 7m, 5m all use a 22mm pin diameter, You can adjust the comp height with the head gasket. Did this all once before many years ago, abandoned the project due to lack of money.
