f00g00 said:I had the new LSD put in today and the gearing is really weird. For one full turn of the wheel its moving the driveshaftabout 4.1. it looks more than 3,91 and less than 4.30, its just barely getting past 4.
f00g00 said:I should have the new speedo gear in about 3 days then I will test it further.
f00g00 said:I ordered the gear from the dealer here they said about 3 days to get it from Japan for my W58.
chris89 said:ok, so u had a Japanese spec w-58, same what i had to put on my car, The gear on the japanese w-58 is smaller, But the speedo cable still works with it, but throws the speedometer off pretty bad.
CRE said:Okay, I've never heard that before. Where'd you get this info? I'm not the only person with an N/A who's swapped in a taller diff and had this issue. I could see it being a revision thing, but can't imagine any reason why they would use a different size gear in a different region. Seriously, I'd like the source... if there is a gear that'll fit I'd like to get one. I've recalibrated my speedo for the time being, but my odometer is still off a bit.
chris89 said:yeah, I"m guessing mine is to, i hate it, that's why i'm gonna get a different US spec w-58 with the Original size odometer gear.
