3P's TCCS Disassembly/Analysis
Jeff Lange
Administrator
4,927
20
Sunnyvale, CA
jefflange.ca
I skimmed through a lot of this thread as well as reading many posts more closely, there was some talk of 1JZ ECU's, has any testing/development been done on the JZA70 ECU at all?
Jeff
8,900
I have read the whole thread now. Good to know there is a solid answer with the Lex meter. Although my car runs and idles very well.
mentat-vvo
12
Vladivostok
JZX100 ECU test. 3 boards running 68pin denso MCUs from external RAM. 540cc injectors from Toyota Caldina. No MAF. Engine tends to stall.
[video=youtube;CQ-52Rz9w2c]https://www.youtube.com/watch?v=CQ-52Rz9w2c&feature=youtu.be[/video]
8,900
When you get around to it...how hard would it be to switch from 550cc injectors to 680 or larger? After you produce the modified PCM.
mentat-vvo
12
Vladivostok
There's a "magic" constant exist in the code. Works similar to the "req fuel" constant in mega$quirt.
JZX90, 1JZ-GTE, MAP-based, also has this constant and could be tuned up to 850cc injectors. Maybe even more.
mentat-vvo
12
Vladivostok
7M-GTE code (gray connectors) for IDA with some comments
https://yadi.sk/d/JLxfDOfH3LeLvZ
I'm currently working on the replacement of a Karmann vortex type AFM with a "hot-wire" one from JZX100.
Also, I'm planning to replace altimeter MAP with a MPXH6400. It is strange that internal altimeter MAP has such a priority along with other ADC channels. Although the altimeter MAP has lots of pins, only three of them are actually used.
mentat-vvo
12
Vladivostok
I've made experimental ECU with stock AFM, equipped with my external memory module + upgrade of the MCU (7433->5B25CT-1, which has +100 bytes of RAM).
Changes that were made:
1) Stock barometer MAP became external; can be easily replaced by an MPXH6400 (20kPa - 400 kPa)
2) A communication port with a bluetooth module / USB-RS232TTL for comms/firmware upgrade was attached
3) 5-pin connector was attached for an external hot-wire AFM (5 signals: +B, VG, THA, E2, EVG); ADC6 was used for this through 47nF/2k7 RC-filter
Stock code will be modified so that I will be able to record logs for MAP/hot-wire AFM to replace karmann vortex AFM either to a hot-wire type or to MAP.
Piratetip
Far From Maddening Crowds
1,179
70
MKE, WI
^ Agreed
Any options available for an 87' 7M-GTE M/T ECU?
Pi, do you have any boards made up yet?
Rollus
593
Paris, France
I guess it's not dead.
I know beta testers (I'm one of them) are not as acive as before. Personaly I've spun a bearing and no time/money/bravoure to repair yet.
