i was going to do it, then i decided against it (money reasons). it will cost a bit, even though the motor set might not. to make it easier send the harnesses to Dr. Tweak and for 500, he will make it plug and play for your car. you will need an adapter plate for the r154 bell housing to the engine, and you will be on your own for the motor mounts. Check out
www.lextreme.com for some info on the swap there, and
www.clubna-t.com also has a section. 2 turbos and a 1uz would be a really tight fit in the MKIII body, but with the right manifold, a gt42 fits rather nicely
. By the way, if you did this swap, you would probably want to go with electric fans for some savings on room.
