1uzfe
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
Ric said:
if you're staying N/A, a 1UZ is junk.
It makes the same HP and Torque as a 2JZGE.
Show me a 2JZGE (especially stock) that makes 250 to 260ft/lb tq, and makes 200ft/lb tq or better form about 1500RPM's all the way to redline, and weighs the same as a 1UZ and then you can call it junk....
The 1uz makes roughly the same HP and TQ as a stock 7M-GTE and weighs quite a bit less and far greater reliability.
tlo86
Ninja Editor 'Since 05'
Jul 24, 2005
3,914
Colorado
Mmmm twin turbo 1uz head + 2uz bottom built like a monster.... will make more power than a 2jz :):)
cjsupra90
Jun 11, 2005
1,029
Lakeland, FL
not the early 1uz heads....... They are the worst. The 98 and later or the 3uz or the stock 2uz heads would be far better.
Tid-bit of info, the stock VVT-i and 2uz non-VVT-i heads outflow a well ported set of early 1uz heads.
