NashMan;1204225 said:i wounder if the 3uz whould drop in if you got tired of the 1uz
i think the 3uz is the best of the series one is glass and shit and just crap forgtet witch one
but whould yae
1UZ 89-94 = 4.0L, alum block,thick rod 256hp/260tq
1UZ 95-97 = 4.0L, alum block,thin rod 261hp/268tq
1UZ 98-00 = 4.0L, alum block,thin rod, VVTI 290hp/300tq
2UZ 98-05 = 4.7L, iron block, thin rod 271hp/315tq
3UZ 01-09 = 4.3L, alum block, thin rod 300hp/325tq
The early 1UZ is the strongest of the bunch, also being the nest candidate for forced induction due to the size difference in the rods.
In terms of money, from what i have gathered, the cost scales as such:
1UZ 89-94
1UZ 95-97
1UZ 98-00
2UZ 98-05
3UZ 01-09
The 2UZ and 3UZ can get VERY expensive, while the early and mid 1UZ are damn near dirt cheap.
In addition, as far as I know, the 3UZ is equipped with anti-theft, similar to the Ford PATS system, where the ECM, key, ignition cylinder transponder, and a seperate Theft control unit all have to be together, or the vehicle will not start.
The 2UZ, while packing more torque and a marginal gain in hp, is a heavy pig. So that throws that one out the window, as an early 1UZ with less power will give roughly the same performance in vehicle as the larger, iron blocked 2UZ.
the 1UZ and 3UZ are 6 bolt main engines, while the 2UZ is 2 bolt. Also of note, the 1UZ uses 2 studs on each side of the crank, and a bolt through the block on each side, while the 3UZ is all bolts. The 1UZ fasteners are stronger, due to them being studs.
My opinion? Go 89-94 1UZ. Then if you want to boost, you have a nice and solid backbone to work with.
