1300 Kg Track SUPRA project
josbeat
483
spain
not possible to be compared , the stock 3 pieces do nothing comparing it with the one I have
it is not the best made rear wing but it works like a real adjustable rear wing, and also the adjustement of it change the car behavior
the negative point is it need other aero bits at the front, lowering the front of the car or mounting an splitter to compensate the downforce if not the car understeering a lot.
wesbeech
Beech Performance Motorsports
Feb 26, 2006
1,022
Akron Ohio
josbeat;1883127 said:
one day testing in a new circuit
and the end the Spec twing disc clutch broke.... when I was learning the track
I'm surprised it lasted that long. Just saying. Lol
wesbeech
Feb 26, 2006
1,022
Akron Ohio
josbeat;1883904 said:
that way! i need a 26 spindle clutch so really I need a racing clutch to suit a coustom flywheel like the quartermaster or Tilton or... the carbon carbon are spectacular spectacular but on the price jejeje
I make a twin and triple. I can do any spline. The twin is rated for 700 torque and the triple is 900 torque. I run a twin and have beat th shit out of it for 3 years with no issues ever.
josbeat
483
spain
Wes i have no idea ... I allways look in your web shop and there have not any comment about clutchssss so now it is a little late, what I did? I sent the clutch discs to be reinforced and they did a good job with new rivets.
but good to know it because never know with Spec jejeje
wesbeech
Feb 26, 2006
1,022
Akron Ohio
Yea there is alot of stuff not on the website. You just have to ask me.
josbeat
483
spain
waiting for the oil pan (stopped in the customs)... I just finished of repair the engine still using a wet oiling system to go to the track next week end so i will use it to setting the chassis with some test , one will be the gurney flap and others will be playing with the chassis height , brake biass , tyre pressures..... ectr.
Beals
JZA70 TT-R
Feb 3, 2009
591
Alberta, Canada
awesome, I wish I had the suspension your car did. I'm working to get their, but replacing the bushing does not look fun. I got coilovers right now and am planning to replace the endlinks well I'm still in college bc their cheap. What do you think is the biggest gain other then that for handling?
josbeat
483
spain
you will need a good set of roll bars
and a set of widest rims
try to set the front heigh a little lower than the rear
if not possible to use an splitter... close the front underneath with a straight plain cover (with or with out the stock one) most probably you will need to make a custom airdam to get it straight ( not sure with stock bumper).
All of those will change the car completlelly and will lower the fuel consumtion.
also a hood vent will lower the fuel aswell and the engine temperature
Backlash2032
1,823
Nebraska
If the car is a DD, I'd stick with stock bushings. I did the whole swap, front and rear and it wasn't too bad, and I'm still debating on swapping the suspension from the old wrecked car to the new one...
Sent from my terrible HTC Rezound using Tapatalk. Don't buy HTC...
josbeat
483
spain
Enraged;1928856 said:
looks good. what are you using for a pump?
thanks!
to much time waiting for the rest of the parts .... i dont remember the brand jejeje
maybe Peterso but no sure , I need to found the Invoice to see the brand but Is a 4 stage pump of a reputable company , you can see it in the 20 and 21 pages
