I don't know why you bother explaining it to them, they're either toyota fan boys or don't really know what they're talking about, either way they're too close minded to listen to reason.
siman said:And you wonder why honda's have short gears?
heck, when I take off from a redlight I routinely rev to 2500-3000 and slowly engauge the clutch.....knowing that I have one of the most powerful clutches in RPS's line...it engauges quite quick.
Dissing on the RB is just retarded....
Give me one example of an RB having a low tq number? Those motors are a marval of modern day engineering. For one, on the stock head...it can handle 9K rpm.....the bottem end can take upwards of 1000whp ( yes just like the 2jz)....and it has MINIMAL lag due to the combustion chamber design and the smaller stroke....
-Jonathan
drunk_medic said:When I put my intercooler on and cranked my boost controller to 13psi, I couldn't keep traction if I launched at 2500. I used to. To hook up correctly and not spin tires, I launch at 1500, and I am only using a TRD sport clutch.
As for the RB - it's stock internals don't handle the same as the 2JZ. I'm sorry, but RB internal kits have been offered for a long time, by many more companies than offer 2JZ internals. There are even replacement cranks - and I'm not talking about doing anything with the stroke - stock config cranks. Maybe they are made with lighter materials, but I'd be willing to bet that strength is more of the purpose - weight savings is just the benefit. This brings us back to strengthening the stock internals AND pushing for higher rpm. Maybe the RB-X motor can take it, but a RB26-DETT needs some internals worked between the 600-700hp mark.
I<3Supras said:Got this off of the site Siman was talking about.
»Top Five 1/4 Mile ETs
# Username Ride 60' 1/4 Mile ET &MPH
1 andrejp GTR700 1.321 8.273@
2 DABEAST VL 1.440 8.960@
3 Munro R33 GTR 1.485 9.459@
>4 Bezerkly 1975 Galant 1.320 9.670@ < there something u don't see everyday
5 theo R32 GTR 1.569 9.759@
drunk_medic said:I know that the phrase "there's no replacement for displacement" has been KIND OF proven wrong [you can take a smaller displacement engine and use boost as artificial displacement by cramming a larger volume of air in the combustion chamber], and people use a little bit of technology to make more out of less, but you need SOME displacement to start with.
Now, the RB26 is a great motor. I don't see where you could catch that I have a bias against them. Simply put though, the 2JZ is the same build quality, with more displacement. Why would I even worry about an engine that I am not ever likely to own or encounter? Given the choice between the two engines, the 2JZ would be my choice, if not for the simplest argument that you can get a front clip with a 2JZ-GTE that has VVTi [I wouldn't want that, but for argument's sake, this is the newest, most expensive model of 2JZ] for less than the front clip from a GT-R33. We're not even talking about a GT-R34 - a '95 Skyline front clip will cost you more than a '99+ front clip of a car with a 2JZ.
Orion ZyGarian said:IIRC, John Shepard's GSX also has full interior...or at least basic interior
