XSPower has begun..
miggles
i wasnt speeding officer
Jun 3, 2005
526
perth West Australia
hey nice work tom,Great to see the progress. Keep at the welding mate,90% of welding is the prep,if you have big gaps,grease,oil and sticking tips etc then your welds arnt going to turn out nice.Do what Ian says,get some scrap steel and practice.Welding exh tubing is more of a advanced stage in welding.Im sure you would have blown holes in the pipes when welding them.If you are welding 2 pipes together use gravity to help you,dont weld straight on top of the join (gravity will pull the weld inside the pipe/tube and blow holes if your not careful) but try to get the joint standing up and pool the weld along it taking your time to stop and weld the opposite to counteract the expansion/contraction of metals when hot.
Untouchable7mgte
back in the game!
Wilkes-Barre,PA
no need sparks everyone and there pet fluffy knows about those turbo housing. old design just like the old SSA mani hitting the oil filter housing they fixed it. Supraboostin indeed it was your idea that made me do that. mines just coated black.hehe. Miggles thanks for the helpful advice i did notice welding the sides were alot easier and coming out alot better other than when i was weldind directly on top. Thanks for all the post ill have more updates when i get new parts in.
Tom Z
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
Sparks280zt said:
I have a picture of a TurboXS turbo apart and the center section is indeed glued together, I will have to dig it up.
that topic has been gone over and over and over on this board, im runnin the mani,wg,and T70 from the company and nothing is glued together
its a pretty tight fit on the downpipe for my car, hows the clearance on yours?
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
Untouchable7mgte said:
the DP is pretty tight. i had to make sure i get the cut perfect.
tom
i just towed my car to my friends shop, and gave him the v-band stuff and let him have fun. Bigzavs=no good at welding
but its lookin good man, and youll like the way it sounds, im runnin 3" crush bent (for now 3.5" on the way) and it sounds mean as hell
Blahman2
12
Pa
There are honda forums? My car doesn't have vteck, but I have nos, an short ram intake, a eiback turbo setup, 4-2-1 headers and a greddy waste gate. I will school you're turbo surpas. vteck is for losers who have no balls.
