WTF is Bitron 4 Real?
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I'll talk to head office and let them know there is a demand for newer lab test results. I'm sure they'd be impressive.
I am convinced Slick 50 is a rip off. It contains PTFE (teflon) particles that Dupont and NASA have tested and shown to actually cause more damage than good by blocking oil passageways and clogging filters. It failed our friction test as well. Here's the video: http://www.echowavepro.com/SG_MED/SG256_Slick50.wmv
Here's a video where we show the problems with additives like Slick50 and Lucas oil (which also made no difference in our tests): http://www.echowavepro.com/SG_MED/SG256_AdditiveIssues.wmv
A video about how Bi-Tron works and how it can polish metal over time:
http://www.echowavepro.com/SG_MED/SG256_Howitworks.wmv
Just for interest's sake, some cars get much better results than others, depending on the design of the engine and fuel injectors, plus how clean/dirty it is. For example Dodge Durango owners consistently report a 10-20% increase in fuel economy (using all products including the fuel conditioner), while some Honda owners report no change in mileage. (I've never tested my Mk3 for mileage changes because I'm always doing hard pulls anyways :))
These are my personal theories:
1. Since the fuel product alters the surface tension of gasoline and it's inherent misting properties, vehicles with dirty or inefficiently designed fuel injectors will get an increase compared to one that is already clean an misting the fuel optimally, because of injector design.
2. Larger, higher horsepower engines with more cylinders consistently report greater increases in power and mileage than smaller engines. I believe that in a low-power engine, the regular film of engine oil is adequate (except on startup or overheating) and is rarely ever exceeded. In high-compression 4-cyl, 6 or 8 cylinder high-performance engines, friction becomes much more of an issue because of the more extreme forces and heat plus more overall moving parts. The more that you exceed the regular engine oil film, hence riding on the "few molecules-thick" bi-tron oil layer, the more the microscopic metal surfaces will smooth out; yielding less overall friction, reducing oil turbulence and tempurature. High tech!
JoeC
338
Vancouver, Washington
tekdeus, I think more people would find you to be a more believable retailer if you were straight forward with us. As if you weren't trying to promote a product YOU sell, but a product you find good, and that could help us out.
(aka) I noticed in your last post the first half with the videos, which have been posted before in this thread, aswell as the link in your comment have them.. seems to just be the retailer inside you trying to make money off of us.
Though, the second half of your post is what i personally find attractive to me. You stated your opinion and backed it up with several examples of why fuel products work the way they do, in certain applications. I'm not sure about every one else, but that made me feel fuzzy inside. Like reading IJ's build thread and learning something new.
I'm just hoping that you are here to help the community as a whole, and not have the community help you. If you could talk with the head guys about the tests that would be fantastic, hopefully I receive an email from them sometime within a day or two with something that I can shoot back to you guys. I hope it isn't something we already have seen. By the way tekdeus, in no way do i have any thing against you. I think you're a cool guy, but a little ambitious. But who says that's a bad thing with mkIII owners?! :biglaugh:
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
Understandable! BTW, have we met at one of the meets JoeC? I am truthful about helping out the community. For a short time I'm actually selling to the local Vancouver guys at my wholesale cost, straight up. I'm selling Dan a one-car pack at cost to preserve his new ride (400+ HP GReddy Frankentsein monster). I gave Don (AKA VanSupra AKA Chickenwing) a bottle of gear product for free to help quiet down his noisy differential pinion bearing. If I have to take the time to package product and drive to the post office, I'd like to make at least $10!
One of the biggest reasons for my ambition here is that I am just totally personally convinced that this product would prevent rod knock. If rod knock is, 99% of the time, an oiling problem causing metal-to-metal contact between the crankshaft and the connecting rod bearing, then it seems obvious to me that if the metal simply could not make that contact, then an engine rebuild would be spared.
The same goes for the oil-starved R154 thrust washer. Plus this could avoid crankwalk for heavy-clutch users that start their engines with the clutch depressed: this is murder on the oil-starved crankshaft thrust washers on startup.
If I wasn't a distributor, I surely wouldn't have gone to the lengths I have to prove the product kicks ass on everything else out there.
I'd suggest phoning instead of email if you want info faster. The guys at head office are cool, and you can call them at 1 (866) 824-8878 or Local Phone: (604) 244 8999
Cheers - Brad
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
By the way, one of the best ways to test this product is to use it in a differential with noisy, worn out roller bearings (i.e. pinion or carrier). This is characterstic of a steady droning vibration or howling noise that can get quite loud on the highway, plus there will be lots of metal shavings stuck to the drain plug magnet. This is different from the sound of improperly adjusted gear backlash which causes the meshing-gear-type noise/whine.
Either add the product directly or with fresh gear lube and I guarantee the noise will quiet down to near-new levels after a few hundred miles. It's pretty darn incredible, it happened to my Mk2 Supra. People love avoiding expensive rebuilds. Here's some videos I shot of other people who had similar results:
mms://stream.yourgalaxy.com/bitron/Hi_product/Hi_JeffBandickFordTCase.wmv
mms://stream.yourgalaxy.com/bitron/Hi_product/Hi_LindaHCadillacDeville.wmv
Anyone got this problem with their diff?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
im with yellow, i've got a few cars i can test this stuff on. i could take a few cans and ill slip some in moms protege. hell, i might even be able to try it in the power wagon.
Clip
Oct 16, 2005
2,738
9
Virginia
and what the hell?
a set of zebras has lasted me two years. no such thing as too expensive.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
hmm...that movie is interesting. the one about the metal to metal contact. the only thing that first came to mind is a slightly contradictory statement...
if the bi-tron is added and does such an immaculate job of mollecular adhesion to the metal, how could the microscopic mountains be rounded down AFTER the additive is in the machine?
maybe it just prevents large divots from forming again?
it does sound feasible. i wish i had more physics background so i could understand the properties of these things on such a small level.
can anyone tell me exactly what is IN bi-tron? if not the proportions thats fine but at least some the oils/substances used? thanks.
i'm definitely interested in a well-documented test and i think that is a HUGE point in allowing people to understand it really works. even better if a fellow SM user other than the seller could test it on a not-so-crucial vehicle...maybe even one that is burning oil or on its way out.
i have a friend with an S-10 that burns oil and just began to die...maybe i could get him to try the stuff.... it makes a cloud of smoke on starts. lol
tekdeus
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
The microscopic peaks and valleys smooth out under load/pressure, since they slide over each other without friction. Otherwise, if the metal does make contact, it just rips up/grinds/roughens up the metal even more.
It is not like the product called "Restore" which supposedly adds metal or moly to fill in rough surfaces (not even sure if that stuff works). So it won't replace worn metal, but it will prevent further wear and smooth out microscopic roughness gradually over time.
In some instances, it can help stuck rings get loose again which can restore compression. Because of this, it may or may not help oil burning issues in highly worn engines. My Mk2 has a lot of mileage and burned a bit of oil when I bought it. It hasn't gotten any worse since I started using the Bi-Tron, so I'm happy that it's keeping it preserved where it's at.
There are so many factors that affect results, I just tell people to be happy that they've eliminated start-up wear and a lot of extra further wear that would have happened otherwise. Many customers do report power and mileage increases, but not everyone does, so I don't promise these aspects but if they do happen it's a nice bonus for the user.
Not sure of the details of how they make this stuff but apparently it is 100% petroleum. Modifed oil molecules. "Bi" stands for 2 and "Tron" stands for electrons. If I recall correctly it is a petroleum molecule that is missing 2 electrons giving it a positive charge and a strong affinity to metal so it is essentially "borrowing" electrons from the metal, forming a very strong bond, that gets even stronger the hotter it gets.
If you want more details, here is a 38 minute interview with one of the leading R&D chemists contracted by Bi-Tron, who served on the SAE and also participated in the development of Techron, offered by Chevron: http://www.echowavepro.com/m3u/product32.m3u
shaeff
Kurt is FTMFW x2!!!!
11
Around
for those who keep saying stuff about changing your oil every 1500-2000 miles, as well as "i need 20/50 because it's hot here" need to search for some posts about oil made by jetjock.
and remember.
Nick M. said:
pressure is resistance to flow.
-shaeff
mkIIIman089
Ohio
and remember.
-shaeff
:icon_bigg Knowledge!
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
i guess the only way i would be satified , with purchasing this product would be if the company, pulled 4 motor's out of running cars, perfebly the same make and modle,
doing this would give 4 identical oiling systems
note millage,
take two of the engines, and perform a rebuild,
all new bearings, hone, new rings, and note, take pictures of all the bearings that came out of the motor, along with how the cams look, i would also say get these 2 blocks hot tanked, to get rid of any sludge build up.
on the other 2 motors, they should have similar millage to the motors being rebuilt, drain all oil, remove pan, and allow to drip for a few days. put pans back on, and choose your oil wisely,
from what im reading bi-tron is just an additive, so i would put the same oil into both motors and ad bi-tron into one of them, run the engines on stands for the length of a month , constant running, of course plumbed with water to allow cooling,
better yet re-install the engines into vehicals, and allow your daughters to drive the vehicals for a month,
for the rebuilt engines, do the same thing except run the bi-tron from the get go, break in and every thing.
maybe a month isn't long enough to tell weather enough wear has happened, so maybe 2 months of daily driving, try atleast to put 2-5000 miles on the motors,
pull all engines and tear down , note bearings in all the motors, and how much metal is in the oil, oil color, and test for other chemicals in the oil.
ps, oil changes color from the blow by in motors, where the compression blows past the rings, and the carbon monoxide and acids from the combustion process change the oil charaterics.
also the chemicals in blow by attrac water to be absorbed into the oil.
well i got to run, sorta got side tracked while typin,
but any how, thats the style of test that i would be happy with
Figit090
Jan 7, 2006
1,835
Humboldt County
thanks for that explination, it helps. i'm definitely going to look more into this.
pimptrizkit - sounds expensive. lol.
i dont remember if you said this but measurements should be made as well...very precise onces with a good, precise caliper.
Figit090
Jan 7, 2006
1,835
Humboldt County
oh...well then. lol. i wasnt necisarily thinking only they would do the test though. it would be less apt to gain suspicion if a 3rd party did it anyway....
jimi87-t
1,127
5
Colorado Springs
What state is this Birtron in, in < 32* F temps and then what state is it in, in > 200* F temps. I've seen some of these additives turn into a an ice cube when put in a freezer over night (this is bad mmmK). There are extreme conditions that oil HAS to hold up to, the test in the vids is nice, but far from an accurate depiction of what oil and any additive are put through in the almost violent changing conditions the oil deals with in the real world.
Not knocking the product, but the vids do not make me a "believer". I would buy cases of this if proven.
BTW: I'm an aircraft inspector, deal mainly with aircraft engine and gear box bearings for the military and commercial aircraft. A few of the bearings I handle cost more than $25,000.00 (thats for one single USED bearing). I'm wondering why the aircraft industry is not using this.......it would save billions a year......if it works.
