Woooohooooo MAFT-Pro is running !!!
chriso
Supranian
Bay Area, CA
Here are a couple screen shots of a log run I did. It is in two parts. Can anyone explain what is happening to my Vf signal and my AFR's are dropping to way rich and perhaps lend some insight as to how I can correct it.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
in the first pic, it looks like the vf is tring to lean out the mix some, then as the afr comes up, it goes down to around 2.5v's and then when you went wot, it droped all the way, wher eim going to assume that the computer went into open loop, and stopped using the vf signal.
chriso
Supranian
Bay Area, CA
Hello, Doc....anybody??? Any other ideas on my settings that would give the above results? Thanks pimp for your thoughts but any idea what I do about it?
chriso
Supranian
Bay Area, CA
drjonez said:
were those WOT runs or just cruising? Vf only applies @ cruise....
Certainly not WOT, maybe mid range. I never got past around 4000 rpms due to the fluctuation of my AFR's and I didn't want to do any engine damage.
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
suprastanger507mgte said:
Add me where?? Chris you getting bad advise man...don't be adding me to your tuning... lololo
Moe
lol my batteries were dieing in my wireless keyboard..
i would seriously advise adding you to any one's tune moe. :biglaugh:
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I record data on tuner pro, but cant play it back! It says i have mismatched ads and xdf file. I have tpro4600.bin, and tpro4600.xdf on tuner pro page, It says ... \Program Files\TunerPro RT\522.ads for definition file on aldl setup page, what do i need here and how do I get it??
chriso
Supranian
Bay Area, CA
I was told to connect the purple wire on the MAP (6 pin) harness to the Vf signal on the ECU and to monitor this on the Aux 1 setting. Does anyone know if I am supposed to turn on Aux 1 Mode as described on page 15 of the manual by changing the setting from "0" to "1".
Come on MAFT Pro guys.....
turbobob
196
Near Detroit
It doesn't really matter, since all the aux mode tune settings are 0. (unless you changed them) (well except boost control.... you running that yet?)
Bob
chriso
Supranian
Bay Area, CA
Bob
Bob,
Well, boost control is set up but I'm trying not to run too much boost since I can't seem to get this thing to settle out. I've been driving very conservatively. I am still having idle and AFR issues. If I sent you a logfile can you decipher it for me and make some recommendations for the settings?
That would be awesome help if you could.
Also, how much are the wires for the timing control. I pm'ed you a while back but got no response. I thought they were free, or at least at one time they were.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I updated to 4.67 to fix a bad lean spike off idle (18-20:1), but now my boost controller does not work correctly no matter where I set it. It spikes to about 6 psi higher then where it is set with the same exact settings it had with 4.40.
chriso
Supranian
Bay Area, CA
I didn't know there was an update to 4.65 out yet. I looked all over full throttle's site but couldn't find it. Is it proprietary???? Malloy said he was running 4.76 (typo???)
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I'm pretty sure it's 4.67, but I can't say it's a good idea to try it yet.
chriso
Supranian
Bay Area, CA
Aaron, were you able to get the rest of the AFR stuff to work through all the RPM ranges??? Care to share a *.bin file?
bigaaron
4,692
Pomona, CA
www.driftmotion.com
Yes, but something was seriously changed from 4.40, so my 35+ dyno pulls worth of tuning were a waste of time because the tune is way off now, which is why I didn't enter the drag races at Vegas.
