mhopemk3 said:It's what the ecu sees as AFR.. 0-5v. 2.5 being stoich..
drjonez said:no, it's not.
it's what the ECU is doing to the base fuel calulation. as always, the info is on MKIIItech.com:
http://www.mkiiitech.com/forums/viewtopic.php?t=593
the point is there really isn't much you can do to stop the ECU from achieving stoich in it's preset ranges (cruise, idle). all you can do is help it to achieve stoich by satisfiying Vf.
Good question....How are we supposed to monitor this. What point is it on the Pro?3rdtimearound said:Are you saying that we need to manipulate the pro's settings while trying to moniter what Vf is doing.
If so, would we use the oxygen feedback mode with afm unplugged?
Moniter it at the diag port, correct?
Wayne
chriso said:Good question....How are we supposed to monitor this. What point is it on the Pro?
Acccording to the 89+Standard Connections page, the purple wire (from the 10-pin Connector) is supposed to go to the wideband ground. Are we talking about an extra purple wire on the speed density harness? If so, does this wire get "Tapped" or "Spliced" into the Vf connection on the ECU?pimptrizkit said:you supost to wire up the purple wire, to the vf terminal on the ecu i belive.. i missed it to... any ways, it should be on of the aux input's or v-input's..
drjonez said:allright guys, i am about to give up. this is NOT hard.
Vf tells you what the ECU is doing. the whole point is to adjust your low and mid maps to bring Vf to 2.5V.
i'm not going to go over the MAFT pro connections AGAIN. click the link in my sig, it's on page 2. ALL wire connections are tapped.....unless you're using SAFC mode.
:3d_frown:
drjonez said:as the install docs show, you connect aux1 to Vf.....so Ax1 = Vf on the sensor monitor page....
drjonez said:does the AFR oscillate around 14.5 - 15.1? that's the "normal" closed loop behavior.
what is your fuel press set @ (vac line OFF)?
based on your Vf reading you need to take a bit out via mainscale or drop fuel press.
